Analog dest problem
claudioD
Analog dest problem
Post by claudioD »
hello guys
I've just reinstalled the system based on 2 Luna s
both analog exits of the 2 boards work only in mono, only one channel works , both on pulsar and Luna (scope 4.5 on XP)
any idea or advice ?
Re: Analog dest problem
Did you restore a Scope for 2 Lunas, but now run it with 1 Luna and 1 Pulsar ?
A clean install might apply, because it's a 2 step process during driver install (one for each card, as they are different).
If the basic install is confirmed working, then manually copy devices/presets from the previous version.
If you have devices that use specific .dsp files, you'll have to follow install instruction, though... it's a small pita, but there's no other way.
best of luck, Tom
