INSTALL ERROR
YISH313z
INSTALL ERROR
Post by YISH313z »
Hello all, its been some years since i have delved into the scope world, ive had this Pulsar 2 card lying around unsed ever since and now trying to install it on an old winxp machine that i had scope installed on. currently getting the following error and hope the card hasn't gone bad, if so put me out of my misery now!
Re: INSTALL ERROR
looks bad. it might be fixable...
Berny Shoes
Re: INSTALL ERROR
Post by Berny Shoes »
Someone on this forum fixes Pulsar Cards. Advertised as replacing capacitors but maybe help with your card.
Give them a contact if needed
viewtopic.php?t=36946
YISH313z
Re: INSTALL ERROR
Post by YISH313z »
Well I swapped it 3 times now on different pci slot same deal, ive given up at this moment and may consider getting it fixed later. justy going to grab a hardware sampler and deal with it
Re: INSTALL ERROR
I had the very same error message and it was the 4 capacitors at the voltage regulator at the bottom of the board.
They are located near (and likely connected to) the 2 SRAM chips, so the message makes sense.
YISH313z
Re: INSTALL ERROR
Post by YISH313z »
I’ve now tried this in the original dp35dp motherboard albeit with win10 and have yet to get it to this point, I’ve made a separate post as well.
Re: INSTALL ERROR
Ah, that is useful information. If the device shows up but the driver fails to bind to it, it might be the driver is too old (defer to garyb again for that). But if the card is damaged, that makes perfect sense.
YISH313z
Re: INSTALL ERROR
Post by YISH313z »
Yep. Bad card.
