The Midi Bench
mausmuso
The Midi Bench
Post by mausmuso »
This is my latest midi device which you might find useful.
It has:
- 3 midi ins
- 6 midi outs (each with their own midi filers)
- Individual midi filter pages (Click one of the Mid Filter button to display its filter page) for each of the 6 midi outs for detailed filtering of port midi data
- Midi filter LEDs indicate if any filtering is applied to a port
- Midi note and CC monitor section (displaying the last midi event on the selected midi in or out port)
- A separate midi out for monitoring the selected midi in or out port
- Mute All button the disconnects all 3 midi in ports.
There are many uses for this device, e.g.:
- acting a single point for midi routing, filtering and monitoring
- splitting note, CC, Prog, or Sys data coming from a midi source
- merging midi data from 2 or 3 different midi sources
- sending midi data to 2 or more outputs on different midi channels
- etc.
I hope you find it useful
regards
maus
The Midi Bench.png (117.49 KiB) Viewed 17200 times
MidiBench.zip
(758.25 KiB) Downloaded 439 times
Re: The Midi Bench
I like the name, the concept and the GUI :) Thumbs Up !
Re: The Midi Bench
I use your older MIDI Device.
Looks like I get a new one.
Thanks Mau
Re: The Midi Bench
PP in the Filter is obviously Polyphonic AfterTouch.
Found out this device responds to the SR Pro (project preset list).
So anyone wanting to have the capability of actual re routing of MIDI and Audio can use the MIDI Bench with a few audio switching devices and actually re route hardware outputs, mixers, synths, fix, etc.
I don’t need that but anyone willing to learn the SR Pro style loading of projects no longer needs to load from the Live Bar>File drop down menu.
Several projects can use a basic project, with MIDI Bench and some audio switching devices. They will re route signals to the hardware Ins & Outs as well as hardware MIDI.
Spectacular….
Spielraum
Re: The Midi Bench
Post by Spielraum »
thx maus +
decelerating we!
faxinadu
Re: The Midi Bench
Post by faxinadu »
great!
http://www.oceanswift.net
Music
