TightnWide
mausmuso
TightnWide
Post by mausmuso »
I released a version of this device before, but this is a complete redesign and adds a couple of new elements.
I have included 3 versions with only skins being the difference between them all.
They all share the same presets.
Features:
- 2 bands (Bass and Stereo) with widths controlled by the xover frequency;
- Full/Stereo/Bass switches are there to help with setup;
- Stereo section 'Ambience' circuitry is based on the Bob Katz's K-System;
- Mid Side is separate from the ambience circuitry and applies to the full bandwidth (bass and stereo bands);
- Bass section can be mono'ed either as 'Hard Mono' or by minimising the pan control (click on the control and move up or down to set the bass pan width);
- Notch filter can be linked to the xover frequency to improve separation (Notch can of course be use separate to the xover);
- 1 band parametric can be used across the full frequency range;
- There are two compressors, a Bass Compressor and an output Compressor;
- The output pan control is there to correct any panning issues caused by the various bass and ambience settings.
Hope you find this useful.
regards
maus
TightnWide.zip
(1.06 MiB) Downloaded 439 times
Spielraum
Re: TightnWide
Post by Spielraum »
thx maus for this toy!
Re: TightnWide
This sounds great Maus. I like the new skins too 8)
Thanks!
mausmuso
Re: TightnWide
Post by mausmuso »
Thanks guys
maus
mk_vip
Re: TightnWide
Post by mk_vip »
Excellent stuff.
Thanks, mausmuso!
spacef
Re: TightnWide
Post by spacef »
you could load a poti, and load the skins as an animation (attributes = bottom, not selectable ) then connect another poti that will control which skin is displayed (val to val connection) with both animations having min val = 0 and max val = 2 , steps = 3 or -1, so you can get all your skins inside a signle device (make sure both potis have same parameters before moving/connecting them, or it may crash, so save before connecting them as crashes are probable). i suggest that your skin-poti should only includes the colored part, not the side panels (it''s easier to move around). Advantage = you manage only 1 device instead of 3.
keep the trick ultra-secret please :-D
Sorry I haven't had the time to download and try yet :-)
plug-ins for scope
SpaceF website
SC website
Re: TightnWide
Used this on my mono SE-02 analog synth.
Thanks Mau
mausmuso
Re: TightnWide
Post by mausmuso »
spacef wrote: Mon Sep 13, 2021 9:02 am you could load a poti, and load the skins as an animation (attributes = bottom, not selectable ) then connect another poti that will control which skin is displayed (val to val connection) with both animations having min val = 0 and max val = 2 , steps = 3 or -1, so you can get all your skins inside a signle device (make sure both potis have same parameters before moving/connecting them, or it may crash, so save before connecting them as crashes are probable). i suggest that your skin-poti should only includes the colored part, not the side panels (it''s easier to move around). Advantage = you manage only 1 device instead of 3.
Thanks Mehdi
I have observed that you do this on some of your devices, but did not know how.
I will have a play with this technique
Really appreciate your advice
regards
maus
