Scope PCI Asio
MrV
Scope PCI Asio
Post by MrV »
Hi folks ,
Wondering if anyone might have some clues about this .
I'm running my main studio system on Win10 i7 32Gb ram Sonic-Core v5.1 with 3 x Scope Pro cards
( I installed S-C for this from the v5.1 64bit zip and it's been running fine , although it lists as Scope 32 bit in Task Manager ?? )
I have Cubase 7.5 and Cubase 10.0.6 installed and all have been working perfectly for a year or two .
Until today
When I uninstalled Cubase10 by mistake ...so I re-installed it.
Now ...when I load Sonic Core and then Cubase 7.5 everything is fine , its working w SCOPE PCI.
But now when I load Cubase 10 and select ASIO SCOPE PCI I get "Error: The Scope Application is not running or Asio Source and Asio Dest are not included ..."
I've tried many times , rebooting .whatever ...Cubase 10 cannot find the Scope Asio but Cubase7.5 does .
Maybe this is simply a Cubase issue ?
Has anyone seen anything like this ?
Regards , Michael
Re: Scope PCI Asio
Re: Scope PCI Asio
1. Backup everything.
2. Blow away C: drive (reformat)
3. Reinstall Windows 10, Scope and Cubase 10. If it doesnt work, start again from point 1. but install Cubase 7.5 not Cubase 10
4. When system working, make System backup Restore point.
5. Make a system restore point everytime you install something new
Dual boot can help the above process. So you can restore the odd missing content from the old partition to the new.
Good luck !
Re: Scope PCI Asio
Just right click Cubase and set compatibility option to Windows8. When you reinstalled Cubase it likely removed this setting. Reinstalling Windows is probably unnecessary.
Re: Scope PCI Asio
So no Cubase wont run without compatibility mode on any modern x64 daw machine ? Kinda weird in this day and age.
Re: Scope PCI Asio
this really matters because?
i'm not saying that it could never be otherwise, but...
Re: Scope PCI Asio
Dante, he’s using Scope 5.1 (for starters…)
MrV
Re: Scope PCI Asio
Post by MrV »
Hey thanks Vallis + Dante , yes spot on about Compatibility to Win8 .
That's fixed it now , as well as for StudioOne5 , same issue .
Actually that's something you mentioned to me already Gary , a year or two ago , but I forgot ...
Cheers , Michael :)
Re: Scope PCI Asio
Goodo ! Glad it works :)
garyb wrote: Fri Jul 30, 2021 9:51 pm this really matters because?
Cos its something else you have to remember from a few years ago :lol:
Re: Scope PCI Asio
Scope 7 does indeed exist, though I presume eventually Win11 & Cubase 12 will require yet another tweak and we'll await Scope X9 with bated breath so that we don't have to edit a shortcut. But I digress...
Re: Scope PCI Asio
Glad I use Bidule with its restrictive 1 take stereo track only… :D
