Asus PRIME B460 Plus & Windows 11 Possible solution
k500zm
Post by k500zm »
I have this mobo and I know you cannot attach a TPM module to it for windoze 11
I'm not going to upgrade to w11 for a long time - but I found this so if you want to upgrade try this - the option is there in the BIOS
"Indeed, I don't have a physical TPM module in my system. But it ends up, there's a workaround.
I fiddled around in the UEFI, where I found a setting to enable Firmware TPM. Under Advanced\PCH-FW Configuration, where I switched from Discrete TPM to enable a Firmware TPM.
Then, I rebooted and returned to PC Health Checker and it said I could install Windows 11 without issue. "
You may have to enable secure boot also in the bios
asktoby
Re: Asus PRIME B460 Plus & Windows 11 Possible solution
Post by asktoby »
Thanks, I've just this weekend ordered a new system based on the ASUS Prime B460 PLUS.
We reached the same conclusion in this thread as you did:
https://www.reddit.com/r/ASUS/comments/ ... ?context=3
It's nice to have it confirmed from two sources though!
