what is the "soundcard module" supposed to be?
bosone
Post by bosone »
I was trying to integrate a USB audio device (my zoom recorder) in my setup.
basically, i would like to use it along my Scope system in Sonar while using scope ASIO drivers in Sonar.
I understood it is not possible to use two different ASIO devices in the same program.
I tried the "soundcard source" module in scope but it does not absolutely nothing...
another USB audio device (my digital piano has an USB output) works but with a latency of some second and with an odd double delay when I hear the sound.
I don't have a lot of hopes, but if anyone has some hint it will be welcome! :)
thanks!
Re: what is the "soundcard module" supposed to be?
that was something left over from v2 or so. it is for soundblaster cards. it was never very cool.
It doesn't use a low latency audio path, so you're going to have a minimum of 150-250ms delay in the audio and quite likely much higher.
