Hi, I only used this system with Scope synthesizers and never used reverbs, but today for the first time I noticed that there is no sound from reverbs.
The dry sound is passed through, but the wet one is silent.
It's the same with all reverbs from Masterverb to RMX160.
The system is based on WIndows XP with dual boot, one boot is for Scope 5.1 and the other boot is for Scope 4.5.
On Scope 4.5 the reverbs are ok.
Hardware is 2x Scope 1st gen cards and 1x Pulsar2 card.
Anybody else had similar issues?
I'm investigating.
Sal
													No sound from reverbs on Scope PCI 5.1 [Solved]
						- Bud Weiser
Re: No sound from reverbs on Scope PCI 5.1
Is it imaginable the problem is the dual boot/ 2 different SCOPE systems on the same machine?djmicron wrote: Wed May 12, 2021 9:03 am Hi, I only used this system with Scope synthesizers and never used reverbs, but today for the first time I noticed that there is no sound from reverbs.
I'm investigating.
Sal
When I used SCOPE/XITE 5.1 32Bit on my WinXP SP3 DAW rackmount, the reverbs worked flawlessly.
Meanwhile, I don´t use that machine and SCOPE 5.1 anymore, so no chance double checking/ comparing these days unfortunately.
And I never used v5.1 PCI even I bought app & keys.
Don't the reverbs use the system RAM to a certain extent?  Perhaps a .dll is getting confused?
The dual boot points to two different drives, so there is nothing shared between them.Is it imaginable the problem is the dual boot/ 2 different SCOPE systems on the same machine?
I think it's something in that direction and I've been able to solve it by uninstalling Scope drivers from the device manager, then after refreshing, I forced it to install from Scope drivers directory.Don't the reverbs use the system RAM to a certain extent? Perhaps a .dll is getting confused?
Thanks for the suggestions.
Sal
