reset user interface window positions
Terrac
Post by Terrac »
After I upgraded windows10 the primary window for the scope program (the one that shows icons of devices and lets you open routing window etc) is off screen someplace.
Is there a key-command to open / close this specific window?
is there a way to bring all windows to this one display, or even just reset all preferences to Null / default so that windows are in their default positions?
thanks all!
-terrac, It's whats for dinner
Minister of tiny plastic robots
CloudFactory
Re: reset user interface window positions
Search the forum about cset.ini - there are posts about changing to classic mode, or even backing up the cset.ini and removing it so it starts afresh.
A couple of links:
viewtopic.php?f=19&t=32454
viewtopic.php?f=1&t=30089
Theres stuff like below in cset.ini ...but back it up first
SFPDesktop_PosX=1800
SFPDesktop_PosY=249
SFPDesktop_SizeX=1092
SFPDesktop_SizeY=624
SFPDesktop_Maximize=0
Terrac
Post by Terrac »
Thank you very much Dante!
I'll make a backup and try some of these strategies.
CloudFactory
Terrac
Post by Terrac »
Cool, I found the offending setting in the file.
x coordinates had become negative. I changed that to a positive value and it's now on screen!
CloudFactory
Sounds like a new monitor was added.
In case this happens again you can also switch from portrait to landscape once Scope is open, and re-center the Live Bar and other GUI’s, drag them into view, etc.
I program on a 24 inch but use a 12 inch USB powered LCD live.
I save the same project twice, one for each screen. Call it Live 1 and the smaller Live 2.
Cheerz
this can help. resave after moving lost windows back into view.
https://archive.codeplex.com/?p=sheepdog
Terrac wrote: Thu Apr 29, 2021 1:59 pm Cool, I found the offending setting in the file.
Waaayhaaay !!! Good ol' cset.ini :wink:
