Where can I get scope v7 manual for xite-1?
MCMASTER STUDIO
Post by MCMASTER STUDIO »
Where can I get scope v7 manual for xite-1? I can't find *.pdf file or something like this...
Thank You
Re: Where can I get scope v7 manual for xite-1?
Don't think there is a Scope 7 manual.
There was a v7 addendum (release notes, attached to this post). The full manual is still for v5, but not much has changed that's outside of the addendum linked to this post.
If you visit the SonicCore website (scope.zone) and go to the support > download page, scroll to the bottom and you will see a section that says "All Products: If the software you are looking for is not listed here, please visit our download server." That section has a button called 'Downloads' that will take you to a directory listing that you can navigate. Scope 5 manuals are under the directory structure Folder: /server/public/scope/scope_application/additionals/
See attached link for the addendum, download the full v5 manual above.
scope_application_v7_build_1705_release_notes.pdf
(497.85 KiB) Downloaded 499 times
MCMASTER STUDIO
Ok. What is the scheme of connection in scope xite-1 virtual routing window if I want to connect scope ASIO on STM 4896 X?
Loptop:
ASUS F3Sr Specifications
Processor & Cache Memory: Intel Core2 Duo Processor T7250: 2.0 GHz 800MHz,4MB L2 Cache
Operating System: Was: Genuine Windows Vista Home Premium
Now: Edition: Windows 10 Pro
Version: 20H2
Installed on: 2020-‎06-‎13
OS build: 19042.870
Experience: Windows Feature Experience Pack 120.2212.551.0
Chipset: Mobile Intel 965PM + ICH8M
Main Memory: DDR2 667 MHz SDRAM, 2 x SODIMM socket for expansion up to 4GB SDRAM
(now) Installed RAM: 4,00 GB
*Up to 1GB may not be available with 32-bit operation systems depending on system configuration.
Display: 15" WXGA
+ 3 external monitors DELL P2418HT (Multitouch 10 points)
splitter Matrox tripleHead2Go digital SE version
Asus Splendid Video Intelligent Technology
Video Graphics & Memory ATI Mobility RadeonHD 2400, 128MB VRAM
Hard Drive: (Was): SATA 160GB 5400rpm
(Now): Seagate Momentus 3Gb/s 750-GB
Hard Drive Model Number: ST9750420AS
Interface SATA 3Gb/s
Cache 16MB
Capacity 750GB
Areal density (avg) 541Gb/in2
Guaranteed Sectors 1,465,149,168
Spin Speed (RPM) 7200 RPM
Average latency 4.2ms
Random read seek time 11.0ms
Random write seek time 13.0ms
I/O data transfer rate 300MB/s
Unrecoverable read errors 1 in 1014
Optical Drive DVD Super Multi Light Scribe Dual Layer
Card Reader 8-in-1 card reader: SD,MMC,MS,MS-Pro,xD,mini SD w/ adapter,MS-Duo,MS-Pro Duo via adapter
Video Camera 1.3 Mega Pixel web camera
Fax/Modem/LAN/WLAN Integrated Intel High Definition Audio chip ( Azalia) compliant MDC fax/modem and 10/100/1000 Base T
Integrated 802.11a/b/g/n
Built-in Bluetooth V2.0+EDR
/3.5G Antenna support
LED Status Indicator Power-on/Suspend
Battery Charging/full/low
Wirelesson status indicator
Bluetooth on status
Interface: 1 x Express card (connected sonic core xite-1)
1 x Microphone-in jack
1 x Headphone-out jack (S/PDIF)
1 x VGA port/Mini D-sub 15-pin for external monitor
1 x TV Out (S-Video composite)
3 x USB 2.0 ports (1 for E-SATA combo port)
1 x IEEE 1394 port
1 x RJ11 Modem jack for phone line
1 x RJ45 LAN Jack for LAN insert
1 x DVI-D port
Hot Keys Instant launch Keys,5 buttons:
Touchpad Lock,Internet access,Splendid,Power 4 Phone,Instant On,
Function Keys:
Fn+F1 Suspend switch
Fn+F2 WLAN/Bluetooth switch
Fn+F3 Access to the E-mail
Fn+F4 Access to the Internet
Fn+F5 Brightness down
Fn+F6 Brightness up
Fn+F7 LCD on/off
Fn+F8 LCD/CRT switch display
Fn+F9 TouchPad Lock
Fn+F10 Volume on/mute
Fn+F11 Volume down
Fn+F12 Volume up
Fn+Ins Numeric Key Pad on/off
Fn+Del Scroll Lock on/off
Fn+Space Power 4Gear +
Fn+C Splendid
Fn+T Power4Phone
Audio: Realtek Built-in Azalia compliant audio chip, with 3D effect & full duplex
Built-in speaker and microphone
Keyboard 19mm full size 88 Key with MS Windows function keys
2.5mm travel
Battery Pack & Life 6 cells: 4800 mAh, 53.28
AC Adapter Output: 19 V DC, A, 90W
Input: 100-240 V AC, 50/60 Hz universal
Dimension & Weight 36.5 x 26.9 x 4 cm (W x D x H)
2.95 kg, (with 6 cell battery)
Security BIOS Booting / HDD User Password Protection and security lock
Kensington lock hole
TPM(Trusted Platform Module) V1.2
Fingerprint
Supplied Accessories Optical Mouse
Carrying bag
Multimedia Software ASUSDVD V7.0 ( *For Basic & Business only)
Power Director V5.0 (*For Basic & Business only)
Medi@Show V3.0 (*For Basic & Business only)
* Premium & Ultimate are with MCE support from Windows Vista
Virus & Tool Software Norton Internet Security 2006
Adobe Acrobat Reader 7.0
NERO 7 Essentials
ASUS Utility Asus Win flash for BIOS and Driver live Update
ASUS Net 4 switch
Asus Live Update
Asus Multi-Frame
Power 4 Phone
Asus NB Probe +
Power 4 Gear eXtreme
ASUS Wireless Console
Virtual Camera
Asus Wireless Console
ASUS Splendid
Warranty & e-support 2-year limited global hardware warranty
1-year battery pack warranty
On-line problem resolution through web interface (BIOS, Driver update)
Bundled software install/uninstall consultation
ASUS software supporting
Hardware: Sonic core Xite-1 black.
DAW: MAGIX Sequoia 15
Can anyone to help me?
Thank You
i'm not sure about your question.
the following is just my opinion.
it's up to you to decide how you route audio. personally, i do not believe there is a perffect way to connect. it depends on what you are doing. i would not simply make a single template to cover all possible connections. that is wasteful, both of Screen space and dsp resources.
i normally have a basic recording and mixing template. then i modify as needed. it takes just a minute to connect things. it takes just a bit of thought, and planning, which is a good thing.
normally, i use the record busses on the mixer to route to the ASIO destintation, since it is rare that i record more than 8 things at a time. if i need more channels, i use the direct outs on the STM mixers to the ASIO destination.
for mixing, i connect the needed number of ASIO source channels to the mixer.
mixing and recording are two separate operations. in the big studios, there are different rooms for each, with different equipment. don't just "mix as you go". this is a very stupid thing that computers encourage. what it leads to is "painting yourself into a corner". it is a bad idea to mix before all the parts are in place, unless its a general mix for the purpose of guiding the next tracks.
Scope is virtual reality. it works exactly the same way as a room full of cables and hardware. Sequoia us merely a multitrack tape machine in that room. the ASIO source is its output jacks and the ASIO destination is its input jacks. if you do not know how a hardware studio is connected, you need some time in the library.
MCMASTER STUDIO
My Dear, Friend,
I know how to connect hardware connections, but I have a problem with virtual routing system. I want to connect Sonic core xite-1 ASIO driver on my MAGIX Sequoia 15 DAW. It can play only on ASIO4ALL driver thru scope xite-1. I need more VSTi and VST with smolest latency and better discratization...
the virtual system is exactly the same as hardware routing.
what ASIO driver are you using in the routing window?
do you put the ASIO modules in the routing window with the correct number of channels BEFORE opening Sequoia?
are you getting any error messages?
MCMASTER STUDIO
Can We make a video call on Skype, Viber, What's up, Messenger?
garyb wrote: Sat Apr 10, 2021 10:06 am the virtual system is exactly the same as hardware routing.
I guess he doesn´t find the SCOPE ASIO driver to select in his DAW.
Maybe the driver isn´t installed properly.
He should also see SCOPE Wave drivers in Win10 device manager/ audio and MIDI devices,- and set it up as "standard" playback device for Windows applications like Media Player or VLC etc..,- no ?
I use Win7 Pro SP1 64Bit w/ XITE-1 and SCOPE v7 64Bit still, so no experience w/ Win10 and SCOPE up to now,- but I guess it´s not so much different.
MCMASTER STUDIO wrote: Sat Apr 10, 2021 1:31 am Ok. What is the scheme of connection in scope xite-1 virtual routing window if I want to connect scope ASIO on STM 4896 X?
You pick ASIO source and destination modules from SCOPE software connection menue, open pulldown menu and select desired number of I/O channels, then connect to STM by drawing virtual cables,- done.
MCMASTER STUDIO wrote: Sat Apr 10, 2021 1:31 am Loptop:
Your laptop´s specs are meaningless for that purpose.
Correct SCOPE installation is important.
When you have a PCIexpresscard slot and your BIOS (or UEFI) allows disabling Intel Turbo mode, E.I.S.T. power savings as well as all the C states, it should work,- good or bad performance ...
More computer performance optimization for realtime audio can be done later.
MCMASTER STUDIO wrote: Sat Apr 10, 2021 1:31 am Hardware: Sonic core Xite-1 black.
Thank You
You say, you cannot select SCOPE ASIO driver in your DAW once you added ASIO modules in your SCOPE project environment ?
In SCOPE application, there are demo projects which already have ASIO modules in the ballpark.
Do you power up XITE 1st, then power up laptop and launch SCOPE before you launch DAW application ?
nebelfuerst
Post by nebelfuerst »
I used samplitude X3 with scope5.1 and scope7.
You just drop some asio source and asio dest into your scope project.
Then I press "Y" in SamX3 to get the settings. At audio settings, I can select drivers.. so I select scope.
Now I can go to a track and choose the output to be some scope asio... worked without problems.
The reason why I left X3 was the lack of this combination to adapt speed to an incoming midiclock.
MCMASTER STUDIO
Sorry, but... I can talk everything and be very clever at the other side of computer. Who can make a video call with me and see the all situation...? It's very long discues to write and send screen shorts...
WhatsApp
Viber
Skype
Messenger ?
MCMASTER STUDIO
After my last post :roll:
Heres a quick overview of how to do it with Cubase - Magix should be similar.
https://www.scopeusers.com/ScopeRise/is ... cubase.htm
MCMASTER STUDIO
Ok. I was tried a log time ago. Why I was asking you to mane video call... Maybe my BIOS or system tweek for works with sound is not very well... And, first STM 1632 is not STM 4896 X different inputs. Thats wky I was asked you better to make video call...
It isn't that noone would like to help you, as much as most of us are getting into the midpoint of our lives and have a fair bit going on with daily grind/family/making ends meet, let alone trying to make music. We're certainly here to help as much as we can, and if someone is willing to make a video call for free I'm sure they will speak (or would have spoken) up.
In the meantime, I believe fra77x2 gives lessons I believe, though I do not know the cost. GaryB has also been known to fix technical issues, and when it comes to 'whole computer' issues that's probably (not speaking for gary here) a paid thing rather than something that falls under support for Xite specifically (and thus falls on SonicCore).
MCMASTER STUDIO
Thank You
