As I wanted to test Cubase9 and Ableton10 with Scope7 ( Xite), I set up a  laptop with expresscard to test it.
Scope7 runs fine, but on Windows, there is no Midi interface visible, although scope project contains at least one input and output  ( in cubase9, ableton10, midiox ). Within the windows-scope-driver, 2 is the number of interfaces.
So I installed loopmidi, but even this virtual device is not visible.
The only visible Midi-device is the onboard soundcard for output.
Asio works as expected.
How do I get these Mididevices visible ?
							No Midi devices visible in Scope7 Win10
				nebelfuerst
						Re: No Midi devices visible in Scope7 Win10
They exist in the upper Scope bar as sequencer source & destination.  When you drag a new one, it creates a new # up to the maximum you set in the driver's UI.  These are independant of card, unlike the hardware i/o devices.
				nebelfuerst
Solved it !! The result is very very interesting !
I controlled the PC with Windows remote desktop. Doing so, ASIO is present, but all Midi-Devices are just visible in devicemanager. No program is able to "see" the midi-devices.
Controlling the PC locally or with VNC, the midi-devices are completely functional.
I guess, this could be an artefact of Win10 input-device-redirection with remote desktops.
Win10 is a piece of crap, but unfortunately most DAW require it.
