Server move soon (done)
Things will be moving to a new server in a the next few weeks (hopefully next two). Last fall John's forum started to come under heavy load from repeated attempts to access it after a small review or interview...I forget where right now to be honest. That traffic took about 6 months to abate. This year we got hit pretty hard right around the time the lockdown went into full effect in the US the first time, which was also co-incident with the riots in several cities. Circumstantial perhaps, but we were under a pretty heavy load again the week of the elections.
Right now, the automated attempts to access the server are still around 10% of peak, which is about 10x higher than normal. It hasn't abated as much as I would like, and so in an effort to shore up security our provider has offered me a newer install for the same price. On the backend I'll be able to move a few packages forward that will make me feel better, and it will give us newer CPU's and probably more ram. We're already using mailchannels for filtering due to a high degreee of spam, and we were using cloudflare (invisible mode) the week of the DDOS's. There's been a few retailers DDOS'd this past week as well, and since this is largely automated from compromised shells & low end computers/routers, there's no telling what's really going on.
Now, one way to look at this is that the security concerns from these two hosts are placing more of a load on the server than we are in terms of other usages (aside from disk space). Once we have moved, my concerns will be eased and my budget will remain unchanged.
So, that's what's going on from my perspective. From your perspective, once I move my primary DNS over and populate all accounts, there should be little change noticed on your end. The downtime is all you're likely to see, hence this notice.
Re: Server move soon
thank you.
Mr Arkadin
Post by Mr Arkadin »
:Thumbs Up:
t_tangent
Post by t_tangent »
+1
Thanks for all your hard work keeping the forum running. :)
ronnie
Post by ronnie »
t_tangent wrote: Sun Nov 29, 2020 6:19 pm +1
Hope it all goes smoothly!
This is likely to happen either tonight/tomorrow morning, or certainly within the next 48-72 hours. Any downtime should be considered a good thing this time. :)
Server move is complete. Sorry Jimmy, you'll have to repost your first soundcard :)
Re: Server move soon (done)
ez
We now have access to OS support through 2024, more ram/cpu (same disk/bandwidth allocation) and most importantly OS-level support for things like PHP-FPM which can help mitigate issues from heavy server loads moving forward.
Spielraum
Post by Spielraum »
danke
Well Done on the move.
