FreqSplit
mausmuso
FreqSplit
Post by mausmuso »
I have to apologize to fatbob for this one.
I had a frequency splitter that I previously built but had not released.
I liked his frequency scaling so much I went back and built one for my device.
Features:
- LP, BP and HP filtering 24dB/Oct roll off
- LP can be switched stereo to mono
- HP has a stereo enhancer (see the schublade at the bottom of the panel) of sorts (not overly happy with this circuit)
- You can bleed input to the output if required
- All filter groups and the input bleed group has 1 x insert (note: when LP is switched to mono you can only use mono inserts)
- filters have mutes and solo buttons to assist with setup
- mix buttons to send filtering to output
This is an insert fx module but if used on its own in the project window the LP, BP and HP have separate outputs should you need them on separate mixing channels or the like.
I hope this device is of some use to you
regards
maus
FreqSplit.zip
(318.43 KiB) Downloaded 519 times
Spielraum
Re: FreqSplit
Post by Spielraum »
thx maus,
like the wheel+display haptic methode, cool idea
will play with it
