the19thbears SDK thread
the19thbear
Post by the19thbear »
First of all:
Moderators: Feel free to delete this if you don't think it's a good idea.
I plan on asking questions here and then hopefully get answers, along with me posting whatever things I find out that I couldnt figure out myself/find in any other documents.
The idea is that other people in the future will benifit from this thread, by reading the questions and answers etc.
First question:
Whenver i try to add an osc and connect it to the "f" out of the "midi voice control easy" (or any other midi voice control) I get"cannot add notification to sync output Midi Voice Control Easy 16.Freq
No matter what oscillator type.
What is up with that? I suspect it's an async/sync thing. How do I fix this?
ANSWER:
Use a "Negative Long" in between the connections.
Also, how do I set the polyphony of a synth?
ANSWER:
Use the "DynVOicesOfParent", make a new pot and connect it to the input. Se the min/max to fo rinstace 1 and 4
How can I make a module have true polyphony? In the sense that I have osc/filter/amp section pr voice? Not just copies of a voice when setting the voice count higher than one.
Would like to have for instance S/H running, in different random ways on different voices, so they dont all "random" the same way.
How should I approach that?
ASNWER:
USe the MIX 2(or any other number). Don't use Add 2N (or other numbers). The latter does not seem to respond t o polyphony
Re: the19thbears SDK thread
stickied
I like this thread already.
Liquid EDGE
Post by Liquid EDGE »
Cool idea. Maybe I’ll join in “soon” 😁
