I got a 15 dsp card that kind of works.
It opens up fine in scope 4.5 and I can load things on it, but whatever midi comes in from the hardware midi input is garbled.
Hanging notes here and there, weird low key randomly triggered etc.
I have not succesfully gotten it to recieve midi from an internal source (reaper etc). Might be a settings thing, might be a faulty card.
It has been about 12 years since i last used scope, but dont you just use the sequencer midi source and connect it to a scope synth?
I also tried to use the built in mini-midi keyboard to trigger synths, but that never works for some reason.
Has anyone else ever experienced these problem?
Next step is to completely remove the cable snake. Maybe it is causing weird shorts. Will route adat out instead and try internal midi.
Really sad because this card works 95% it seems.
If all fails, I will go for the "bake in oven" approach. I have salvaged a macbook pro that way in the past.
