Looking for DAS/DASGOST linear crossover files
Peter Drake
Post by Peter Drake »
Hello Scopers,
DAS had a freebie for ConvolveQ owners, a linear crossover, that was a download on the DAS site. Alas, it appears that the DAS site is gone, and I can't find the files anywhere.
If you have the files I would be very grateful to get some copies from you. Alternatively, if anyone knows how to contact the DAS people (Olive?) perhaps that would be helpful.
Peter
Re: Looking for DAS/DASGOST linear crossover files
From memory, tgstgs (Thomas) from DASGost was involved in that - at least he worked on the FFT (?) so if you cant track DAS Gary or Holger might be able to help. Maybe put in a support request to get the ball rolling.
Liquid EDGE
Post by Liquid EDGE »
+1
I swear I had the files at some point but can’t find them anywhere now.
What is it even for this plug in?
Can you give me an indication as to filename?
There's also this: https://web.archive.org/web/20190224022 ... osoft.com/
(For some reason I keep a textfile with links like that in my personal archive alongside relevant files.)
sunmachine
Post by sunmachine »
You can also search for all saved files for DAS in the web archive with this URL by the way: http://web.archive.org/web/*/http://www ... soft.com/*
(This works the same for any address of course. Simply replace http://www.digitalaudiosoft.com in the above URL with any other address. Example: http://web.archive.org/web/*/http://celmo.com/*)
Using the filter field you can then filter the list to only show files with extensions like .zip, .exe, .dev, .mdl, .pre, .dsp etc. for example (or any other part of the URLs/file names).
Liquid EDGE
Yeah I did try that but it seems that the files in question were hidden in the “user area”.and that whole section is missing from the archive as it would of needed a log in? (But I don’t remember ever creating an account with them and I’m sure I had those files at some point, but I had no use for it so just deleted it I think). I couldn’t find a link anywhere that would download those files.. there are other links scattered about on the archive of the site that download loads of the other files (such as their other free stuff not linked to a activation code of another product)
Maybe I’m missing/not seeing something.
Directory listing from my archive's folder for DAS devices, which was curated during the v7 era:
Code: Select all
Digital Audio Soft 64bit Version Files\DAS C350.zip
Digital Audio Soft 64bit Version Files\DAS LEGEND.zip
Digital Audio Soft 64bit Version Files\MASTER IT EQ.zip
Dynamic Bundle Updates\DAS-1610ST4live.zip
Dynamic Bundle Updates\DAS1610.zip
Dynamic Bundle Updates\DAS2A.zip
Free Devices\DAS 4B EQ.zip
Free Devices\DAS TAPE ECHO.zip
Free Devices\DAS TR1D.dev
Free Devices\DAS Wah-Wah.zip
Free Devices\DAS xtc mixer.mdl
Free Devices\Digital Analog Sound.zip
Free Devices\Insert4xtc.mdl
SC 4 DAS_1610\SC 4 DAS-1610++.zip
XITE-1 Versions\DAS 32X8 Mixer
XITE-1 Versions\DAS C350.dev
XITE-1 Versions\DAS D-Verb.dev
XITE-1 Versions\DAS GRIESVERB.dev
XITE-1 Versions\DAS GRIESVERB.pre
XITE-1 Versions\DAS LEGEND.dev
XITE-1 Versions\Das_Xited_Mixer.mdl
XITE-1 Versions\MASTER IT EQ.dev
XITE-1 Versions\REV 224 LCD.dev
A550EQ.zip
DAS C350L.zip
DAS SC_GATE BLACK.DEV
DAS-1610++.zip
DAS-2A.zip
DAS-SC-GATE.zip
DAS_BRICMASTER_PRO.zip
DAS_C350.zip
DAS_Comp_AI.zip
DAS_FM_Bundle.zip
DAS_LEGEND.zip
DAS_Master_IT_EQ.zip
DAS_Reverb_Bundle.zip
DAS_Rode.zip
DYNPARA MS.zip
files2.txt
Goodies dynpara.zip
Installation Digitalaudiosoft.pdf
MASTER IT EQ LT.dev
MASTER IT EQ LT2.dev
N1084EQ.zip
POLTEQ.zip
RMX160.zip
RMX160UPDATE2009.zip
SURROUND PAN reverb bundle.zip
Another folder of free devices, collected between the 3.x > 5.1 era, not as curated and note some names are directories, not files.
Code: Select all
000KS.zip
1HYPERKNOTT.zip
1StringsMK1andGndPianosBetaByAries.ZIP
30-analyzerblue.zip
30analyz.zip
4Band EQ's.zip
ambiseq-ii.zip
amp_ir.zip
Ars Resonar.zip
ASP 8-Band Graph EQ_nC.zip
azymute
Bass_T_Phaser_Free.zip
BDX 01 S.zip
BigMixer V2B.zip
BOS-filthAR.zip
Celmo
chopp.zip
CHOPSHOP.zip
ClapLab.zip
ClapLabRD.zip
Colossus_v0_3.zip
cyprox.zip
DistoExCiter.zip
Dmute
dNa
DNAMusic.nl
Dub Station Dual Chanel.rar
DynaMyth2_0MIDI.zip
ECC83TubeSimulationB1.zip
Electro.zip
empty_32.zip
exciter v 0.9.mdl
Faxi
feemee(p).zip
files.txt
Filter-Collection.zip
Final Liza.zip
fm4.zip
Formant.zip
FrarpSy.zip
freemaryjane.zip
green.zip
HighTimesVU.zip
HighTimes_S_v0_3.zip
infiniti2.zip
j9k
jaded800
KnottsboxVinal.zip
KS-8080-FM.zip
KS01.zip
LE-1 final.zip
LexiconPlate.pre
MCCY
MD1.zip
MidiTransformer1.zip
midi_alternator_v0.6b.zip
millennium bug day1 2000.zip
Mitch.zip
MIX16_S_v0_1.zip
Mix2.zip
modcon_basic_pack.zip
modular
Modular Insert.zip
MOVEQfree.zip
multifilter1.1.zip
Neutron
New_Pianos_Beta.ZIP
peakaboo_v1_0.zip
PF2.zip
PhonoPreAmp.zip
PlanetZ Devices
plastic_too.zip
PRJ Preset List.zip
RSPV-01.zip
S-M-S Insert FX plus_1.zip
Sateq1_0.zip
SATEQ2_0beta.zip
SATTEQ1_2.zip
Saturn_Jngaelin.zip
Scope_Spectrum_Analyzers.zip
SD800-S_v1_0c.zip
Self Multiplier-mod.zip
Self Multiplier.zip
shapenighter.zip
Shroomz
smooth-filter.zip
Spacef
Spielraum
Spring03.zip
spring05a.zip
Stereo-Filter-Collection.zip
styledriver
submodevz_preview_b.zip
Talker.zip
TangentPiano1BetaByAries.dev
TD-1 final.zip
TD-1 XmiX 2007.zip
Tempo-Delay-I-free.zip
TightRoom.zip
Trident_v03v.zip
TubeFilter_v0_5.zip
TubeStrip_S_v0_5.zip
TubeStrip_S_v0_7.zip
TUBE_TAPER_01f.zip
UltraVal_v0_1s.zip
UltraVal_v0_1t.zip
UM-1280.zip
Unisix.zip
Unison6.zip
uniz_mono.zip
U_Flo.zip
v2_d_tune.zip
v2_FrogAmp6Free_2.zip
v2_MICROBE(p).zip
v3_level_one.zip
Vectron
VM_42_v0_5.zip
Wave5free.zip
Wavelength
Wolf
XLlight.zip
XOver_I_S.zip
Xtreme_Cut_Pro_v1_0.zip
I did not put time into recursing this last list as it had to be hand sorted in the above list (no files from subdirs are present, dirs are inline in the list rather than separated from files, etc)
Liquid EDGE
Could it be Rev 224 lcd… or in the digital audio sound zip..
Does rev mean reverb? Does lcd mean linear crossover device.. 🤷‍♂️
Thing is Convolveq is a dasgost device..
I would have created either a DAS or Ghost folder, if it's been sorted. Don't think I have that in my Scope installation folder (which is now a backup/archive from x32 system) but will look.
Rev 224 LCD is in the DAS_Reverb_Bundle.zip file: DAS D-Verb.dev, REV 224.dev, REV 224 LCD.dev
So yes, reverb.
"Digital Analog Sound.zip" contains a dev/dll/pre of the same name "Digital Analog Sound.dev"
Liquid EDGE
Cool, that clears that up. I wonder if I ever backed some stuff up on cd… I’ll have a look at somepoint..
I probably have a few CD's of stuff somewhere. I am fairly good at moving archived data though, so it would take a bit of sorting to see what's in there that I don't have already.
The same goes for the newer files archive. Any recent uploads that work in these forums are random strings of letters, and some portion of those have broken links that are likely unrecoverable. But there are two separate areas on this server where I can look for files, the downside is there are quite a few and they are unsorted all in one folder. The oldest stuff is the least standardized in terms of naming too. In this instance, having the filename is the point of all of that...
...but since I have an eye to making this platform more accessible overall, it probably makes sense to not only continue to restore the broken downloads (where possible) and also curate things manually to identify interesting stuff. Ie, that would be another way to identify stuff like this, if we can't figure out the filename.
Peter Drake
Thanks for searching for this. I would imagine that anyone with the ConvolveQ would have downloaded this crossover as well, but ConvolveQ is a very peculiar equalizer so I don't know if many got sold.
I contacted Thomas some time ago and he said Eric created it so DAS had all the files.
Along those lines, I was hoping to get a customized version of G.O.S.T. Harmonic, but Thomas says he no longer has a setup to work on it.
Would be nice to open protected devices in SDK and modify, but sadly there are dishonest people out there that ruin the fun for everyone. At least Scope has a protection scheme that doesn't degrade performance or take up resources in the host computer.
