Can't sync or playback at 96k
medway
Post by medway »
I don't usually use 96k but today I tried and am having some issues. When sending clock from my Mytek 8x192 set to 96k the readout on Scope says 48k. I remembered reading that was just a display bug but although I see signal coming out of Scope on the meters nothing plays on my converter.
Alternatively setting Scope to master at 96k also results in meters on Scope working but no output on my converter.
The Mytek supports up to 192k so it should be fine but any ideas if the issue is on Scope's end? I'm still on V5 btw (Win 7 x64).
Re: Can't sync or playback at 96k
Sending clock via?
medway
Post by medway »
Mytek 8x192 and ADAT (Pulsar 2).
medway
Post by medway »
Do I need the SMUX? Maybe ADAT doesn't work on 8 channels and 96k?
Correct on that front, ADAT can only carry 4 channels @96Khz because it combines the 2@48Khz via SMUX into 1 bonded pair.
medway
Post by medway »
Thank you.
I got it working with Scope as the master but when I try to sync it to the converter set to 96k Scope shows it as 48k and it won't play. Is there another trick to get it to sync?
medway
Post by medway »
Whoops just saw the S-mux option for sync, working fine now :)
