Pulsar 2 license to another Pulsar 2
Gabriele
Post by Gabriele »
Hi, I have three Pulsar boards (Pulsar 1, Pulsar 2, Pulsar 2 xlink).
I believe Pulsar 2 has some kind of problem. I would like to deactivate it but then Scope 7 would not start because it is licensed on this card. Is it possible to transfer the license to another of the two cards that have remained intact or should I buy another license?
Thank you..
Re: Pulsar 2 license to another Pulsar 2
Email support here: http://scope.zone/
GaryB may respond here as well, so check back soon.
yes. you will need to send the card back to get the license transferred for free.
write to support.
Gabriele
Post by Gabriele »
Ok thank you for the info..
p.s. If I send back the card can it be repaired?
no, sorry. there aren't any parts...
Gabriele
Post by Gabriele »
Ok...I'm not completely sure if Pulsar 2 is really damaged. But I think that's the cause of my system freeze. It is a card I bought used 17 years ago and since I have it the system freezes every now and then (rarely anyway). So I wouldn't want to send my card in vain. Would there be the possibility to activate a trial version of the software? So I could test the system if it works stably with only the other two cards.
sure!
again, that can only be done by contacting support.
Gabriele
Post by Gabriele »
Perfect! I will contact the SonicCore support...
Thank you very much Garyb!
