Special Deal - Never to be seen again !
KrOn has been on a reduced price for a few weeks now.
The offer has been extended until July 14th: 69 € instead of 99 €
- Get KrOn now at reduced price and get KrOn II + Mini Kron II when it is released (around July 15th), at no extra-charge.
highlights:
- KrOn II has a latency-free "Quad" modulator (sequential switch), so you can now sequence the step sequencers (allows 64/128 steps, eventhough the max length is 256 steps). Also includes a play mode where you trigger manually each 4 modulators of the quad sections (launching step sequencer patterns manually). The Quad Modulator is not in the mini version, which already allows to build 16 or 32 steps sequences (and more with the use of program changes).
- New T Mix modulator. They are different in KrOn II and KrOn Mini but they allow the same, ie mix modulators together to use as triggers with the envelopes or external gear.
- better colors, text displays etc
- Random modes everywhere
- Allows more, and does not take more DSP than before (may be slightly less)
- other stuff....
Please note: Mini KrOn II will be available separately at a price lower than 69 € (so not interesting to take the deal if only interested in the smaller version). KrOn II upgrade from KrOn I should be subject to a small support fee (affordable to all). Thanks for your understanding.
Offer in the shop --> https://spacef-devices.com/product/kron/
A few words about KrOn II mini --> https://spacef-devices.com/news/announcing-kron-ii/
KrOn II Beta Panel:
highlights:
- other stuff....
KrOn II Beta Panel:
				- KRON-IIMax-PREVIEW-02.png (780.24 KiB) Viewed 17300 times
						Re: Special Deal - Never to be seen again !
That’s a real beauty of a device Mehdi.
Thanks !!
Here is a short video with tempo variations, controlled by Midi CC
--> https://www.youtube.com/watch?v=NzDFWzy85Mg
and a longer overview
--> https://www.youtube.com/watch?v=2bV6PB6eeKA
Have a nice week!
Have a nice week!
- Sounddesigner
Will Kron 2 work at 96khz samplerate on XITE-1 when it is released?
For the moment, it is too big for 96 Khz. You can load 2 at 44.1. 48khz looks fine too.
@96 Khz it is possible to use 2 Mini-Krons; they load without problem at 96 khz.
I will see if I can do something "in between" in terms of dsp usage, just for 96 khz.
(beta panel, work in progress)
				- MINI-KRON.PNG (469.2 KiB) Viewed 17149 times
it's not a big deal, but on the Kron page there's some html code that you probably wouldn't want there.
I correctedt he pages, it was an old page with code from the old page builder. should be fixed now  thanks
 thanks
						 thanks
 thanks- Sounddesigner
Space-f, I just purchased Kron from you and i look forward to the free Mini-Kron upgrade. I hope you can make a "in between 96khz version of Kron". I just bought Kron now so that i can get mini-kron later and to fund your attempts at developing a scaled back 96 khz version. Thank you for your response and effort to come with a good solution for 96khz, and thank you for a great product's development! I look forward to using some version of Kron!spacef wrote: Tue Jun 23, 2020 9:09 pm
PS. Still loving Echo 4 and your ambient delay! They truly are special and amongs the best!
EDITED
Thanks Sounddesigner, it is very appreciated.
I have sent you an email for the activation process.
Yes, I have already planned the 96 khz version. I must finish what I am doing now and will begin shortly.
LEt's stay in touch
Mehdi
LEt's stay in touch
 Mehdi
- Sounddesigner
I'll definitely be keeping a eye on Kron's future developments. You have my attention for sure   ... Good luck with all versions of Kron! Your email was received and responded to. All the best!
 ... Good luck with all versions of Kron! Your email was received and responded to. All the best!Re: Special Deal - Never to be seen again !
Let's play it like kickstarter
Dev news update
I often need to post a pic publicly because then I realize things that are wrong, stuff that I don't see at home while making the device.
I added "inverse" button on almost all mixer slots, because it is really needed with eurorack. The inverse also acts like a kind of polarizer with LFOs, making them easier to use with external synths (they will sound as you expect them to sound).
I also re-implemented the LFOs fade in/out, because i finally found the right values to make it work in an interesting manner, and it is really cool. It is triggered by notes-on only.
I think I am going to redo the whole output section of Mini Kron, because right now it has the same switch as the big KrOn, with "--" when there are missing modulators. This was done for compatibility of presets with the big KrOns, but it looks a bit unfinished. I will make the right outputs for mini-KrOn without thinking about preset compatibility of the outputs, because the occasions where a user exchange presets between those two devices are not numerous. Moreover, presets are compatible, sub-preset lists are useable, and the few values that need to be manually reset after a preset is exchanged, are less than a dozen.
There are two other devices that are not yet ready for show time, and it is a big KrOn, cut in two (Pitch and modulators with a quad switch) and that can be connected together if needed.
Naming is difficult but we'll have this:
- KrOn 2 Max: includes tables for DSP, V/Oct, Hz/V
- KrOn 2: includes DSP and V/*Oct only (no Hz/V table).
- Mini-KrOn 2: cute and efficient, great for smaller dsp setups or limited number of external synths/modules.
- Pitch 64: 2*32 step (pitch+val) with quad
- Moduls: the bottom of KrOn, without the pitch sequencers (well, pitch 3/ 8 steps is still there).
- May be I will do a "Trigger 32" seperate device. but that will probably be for August/september because it requires a rebuild of some parts (+ experiments of various functionalities, additional graphics etc).
The 3 first devices of this list will be ready for mid july as initially announced. hopefully the other ones too, but an extra week or two might be needed for those ones because unplanned redesigns are always necessary.
Cheese !
Dev news update
Cheese !
				- KRON-2-MAX-BETA.png (161.93 KiB) Viewed 16753 times
				- MINI-KRON2-BETA2.png (389.99 KiB) Viewed 16753 times
btw, if you bought KrOn after 1998 (before JC), the update to KrOn 2 / KrOn  2 Max will be free. it is the additional/smaller devices that are not included in the update.
Some spacey trance pre-1995 style KrOn + Eurorack + BB3 Osc 2
it's more or less the default preset of KrOn 2 ...
Details on YouTube
Play ---> https://www.youtube.com/watch?v=63dLKQ3 ... e=youtu.be
Details on YouTube
				- YT-THUIMB.png (517.99 KiB) Viewed 16641 times
KrOn & KrOn Max pack updates are ready for download from your account on https://spacef-devices.com/
Free update. No new manual for the time being: KrOn 1 manual covers almost everything, and the additions are not very complicated to understand. However, feel free to ask questions in a KrOn's thread of your choice.
KrOn now includes
Kron v1 (now legacy device)
KrOn 2 Max (DSP, V/Oct, Hz/V)
KrOn 2 (DSP and V/Oct only)
KrOn 2 Mini
KrOn 2 Mini b (for laptops)
Volcano DSP synth
JunZ DSP synth
Midi to CV
KrOn Max Pack now includes
KrOn v1 (now legacy device).
KrOn 2 (DSP and V/oct only, no Hz/V ).
KrOn 2 Mini
KrOn 2 Mini (for laptops)
Volcano
JunZ
Spirit
Magma
FMZ
Mini FMZ
Midi to CV
Pics of the mini Kron 2 a and b:
KrOn now includes
KrOn 2 Mini
Volcano DSP synth
JunZ DSP synth
Midi to CV
KrOn 2 Mini
Volcano
JunZ
Spirit
Magma
FMZ
Mini FMZ
Midi to CV
				- Mini-KrOn-2-b.jpg (179.24 KiB) Viewed 16601 times
				- Mini-KrOn-2-a.jpg (176.94 KiB) Viewed 16601 times
If you need to reserve a copy at the price of the current offer, just PM me and I will send you a code that will be valid until begining of August.
Awesome.
Your website looks fantastic too.
				Xite Knight v2.0
- Location: The Kingdom of Denmark, including The Faroe Islands and Greenland
Hi Mehdi (or anyone else who can help). I have a (maybe stupid) question on the 'Quad modulator' related to the quote above from your very first post in this thread. I hope it is ok to post my question in this same thread.spacef wrote: Sat Jun 20, 2020 5:44 am
highlights:
Btw, KrOn is a killer product.
Initially, I assumed that I could achieve 128 steps by using the Quad modulator, but so far, my max. is 64 steps.
I used KrOn Pitch64 in my video below, but I get the same result in all other KrOn versions.
I have selected the following in my KrOn Pitch64 Quad : Pitch1 32, Val1 32, Pitch2 32, Val2 32. (actually I selected Pitch1 32 in the video instead of Pitch2 32, by mistake, but it does not change anything)
With those settings, I expected that I would get 4*32 steps - i.e. 128 steps out of the Quad output - assuming that Quad would run through all 32 steps of Pitch1 32 before proceding to Val1 32 etc.
Instead, I get 64 steps: As you can see in my video, Quad runs through the first 16 steps of Pitch1 32, and then jumps to Val1 32, runs through the first 16 steps there, etc.
Am I doing something wrong or is the max. coming out of Quad indeed 64 steps?
https://youtu.be/uH1lN3syMQU
				Xite Knight v2.0
Update. Right after writing this, I found a workaround. Typical.
So when I change the "Seq. Speed" from 1/4 to 1/2 I get the 128 steps that I expected. Now the steps procede at double speed, but I can compensate for that by halfing the BPM from 94 to 47.
If there is any other way to achive 128 steps without halfing the BPM, please let me know
In fact the calculations are based on 16 steps. The Quad sequencer must run 8 times slower than the main sequencer (16*8=128 steps). I think the reason is because it was not meant to run slow in the begining, but rather for fast modulation so a base of twice the main tempo was chosen  it's only months later that it was possible to use it for long sequences. Anyways it just means the Quad runs at twice the speed of the main Seq Speed.  The MAin Seq Speed is not for 32 steps, but for 2*16 steps (it looks the same but it is not  )
Check the info on the picture below.
Here it works fine. I can switch the Pitch and Val sequencer for 32*4=128.
basically, when the main Seq Speed is at 1/1 x 1, the quad sequencer should be at 1/2 divided by 4.
basically, when the main Seq Speed is at 1/2 x 1, the quad sequencer should be at 1/4 divided by 4.
There is a limit in how slow scope can go, but it should be fine even at 60 BPM.
Let me know how it goes.
below: gif anim. open in new tab to see 2 pic examples (5 seconds loop)
 ) Check the info on the picture below.
				- KRON-128-STEPS-2.gif (311.5 KiB) Viewed 12652 times
