1Vu Mixer Family
mausmuso
1Vu Mixer Family
Post by mausmuso »
Hi There
Who needs more mixers right?
Well here are new 16ch and 12ch mixers for those that are interested.
They are based on an earlier mixer I built where channel views track fader movement.
The tracking system has been overhauled and is now more robust.
One of the design aims was to pack as much functionality in the smallest screen space and you will see there is two versions of the 12Ch mixer, with one collapsible to further reduce its footprint if required.
The Auxiliary channels may be switched for use as internal busses.
Keep in mind switching is global for each Aux/Bus Channel across all channels.
There is a short manual included in the attached zip file that should explain most of the unique functionality.
Hope you find these useful.
regards
maus
1VUMixers.7z
(13.93 MiB) Downloaded 510 times
Re: 1Vu Mixer Family
Perfect timing. I’m going nuts learning things, this might help extend that.
Looks so good it must be great.
Am I tripping or does touching a channel give you access to every parameter as the shaded channel strips everywhere make me think so....a most efficient use of Space.
So would I also be able to right click on an AUX, and because of the shading/color difference, remember that CC?
I dont remember mixers having that, if it's new I welcome it.
Spielraum
Post by Spielraum »
many thx for your toys !
mausmuso
Post by mausmuso »
dawman wrote: Fri May 29, 2020 10:35 am Am I tripping or does touching a channel give you access to every parameter as the shaded channel strips everywhere make me think so....a most efficient use of Space.
Hey Jim,
Yes you can cc the aux/buss switches if you need them.
Just don't choose a cc number that is used on faders to track the channel views, otherwise you will loose tracking on a channel.
I made the aux/busses switchable mainly to save screen space.
Remember when you have a buss channel switched in the aux inputs for that channel will, of course, not work as Busses are only internal.
maus
LorenOA76
Post by LorenOA76 »
Hello Maus,
Wonderful job, like always very intuitive mixers and pro tools for the community !!!
Look so good and work very well in my Scope 7 system :)
At the first use i already fell the knowledge put in the development of theses mixers .. wow!!!
A B I G T H A N K S !!!!
mausmuso
Post by mausmuso »
Thanks LorenOA76.
I have been driven by trying to make this whole channel tracking system work as I envisaged.
Its not 100% but seems to work ok now.
Regards
maus
Spielraum
Post by Spielraum »
mausmuso wrote: Sat May 30, 2020 6:24 pm ... Attached is updates mixers as I found Aux/Bus 1 mute was not working.
Regards
maus
Fx Splitter v1_1_2.7z
thx maus!
pleace clear up me. this v1.1.2 contains "only" v1.1, and why post here, not here in FX Spitter
and why in .7z ?
the most widespread classic .zip uncool ?
LG
:P
mausmuso
Post by mausmuso »
Sorry guys
Whoops mixed up the zip files. That's what you get for rushing, I was on my way out at the time.
I use .7z because that is what I have at hand, sorry again, I did not intend it to be difficult to deal with.
maus
mausmuso
Post by mausmuso »
Ok,
I have finally fixed the cluster f*ck from yesterday.
Attached are two 'Zip' files (too big for one file).
Note the 12 channel mixers have been updated v1.2 to fix a problem with the phone outs.
Regards
maus
1 Vu 12Ch.zip
(10.56 MiB) Downloaded 414 times
1Vu16Ch.zip
(7.01 MiB) Downloaded 438 times
Spielraum
Post by Spielraum »
nice!
also .7z is ok, but libary-repack to classic .zip here ;) (or classic .rar)
Thanks again Maus
