gigabyte x58 ud4 and windows 10
bosone
Post by bosone »
is anyone using the gigabyte x58 ud4 motherboard with windows 10?
any issue??
i see there is no official driver...
thanks!
Re: gigabyte x58 ud4 and windows 10
it should work.
the chipset drivers are from Intel, and they will work. other peripherals might be a problem.
bosone
Post by bosone »
thanks!
my other peripherals are just scope and the video card, which could be changed...
i suppose HDD/SDD chipset will be supported as well. i don't use raid or any other stuff from the mainboard (lan, audio, etc)
Give exact model # (and revision if possible) for onboard device evaluation.
All of the Bloomdale era Ultra Durables were used by Vision DAW for several years.
They claimed 100% customer satisfaction.
djmicron
Post by djmicron »
Had the UD7 model, it's a solid motherboard, only 2 issues were slow post initialization and the low quality Marvell SATA chipset.
Your model should be free from the Marvell.
Also it's a motherboard very selective on the installed RAM, so check compatibility and don't use mixed RAM.
It's a very good motherboard and click free with Scope from my experience.
