UPDATED TO V2
A handy set of devices to label your source/dest and patch bay i/o.
"Label 8+" just added: include colors and icons for your jacks.
Presets of both devices are compatible.
Editable text displays for:
- Source/Dest: for your Adat, Z-Link…
- Channel number: in general from 1 to 8 (ADAT / Z Link source dest)
- Name: to name your source/dest (eg, guitar, synths, effect units)
- Bay: for your patch-bay i/o.
Also includes:
- Color Selector pot
- Display for the preset name.
- Preset ready
The device also contains i/o which are simple “thru” connections: you can connect the device in between your source and destination. You can also leave it unconnected.
Download: https://spacef-devices.com/news/labels-8/
SpaceF - Label 8 & Label 8 +
- JACKS-ANIM.gif (58.37 KiB) Viewed 4345 times
- AnimLabels.gif (34.33 KiB) Viewed 4561 times
Re: SpaceF - Label 8
That is so considerate, and for me extremely useful.
Praying it can be screenset capable.
If not, give it a numbered preset in Speilraums modified Project Preset list and call it up from the controller.
Win win situation.
Thanks Mehdi
Win win situation.
Thanks Mehdi
the show/hide is on screesets but this panel does not have position pads, so it will only show/hide using its current position.
Re: SpaceF - Label 8 & Label 8 +
UPDATE TIME
- "Label 8" (v2) with updated and added colors (50 now, all are now useable with the white text).
- "Label 8 +" : adds jack shapes, colors and codes, and a source/dest switch that changes the graphics "direction".
To change the jack colors, grab the color icon and use it like a rotary knob (far away from the center for slower changes between colors/shapes).
TIP (pics below): it is not always easy to see which is the white and yellow "ring" colors --> the white ring is just after the "plain green" and the yellow ring is just before the "orange ring".
TIP 2: you can import label 8 presets into label 8+ . you will just need to change jacks and source/dest type to taste the upgrade. Pay attention not to overwrite your "Label 8" preset file with "label 8+" preset files. They are both compatible anyways, bit label 8 may not recognize the additional parameters from label 8+ presets.
More info https://spacef-devices.com/news/labels-8/
- whiteRING.png (2.71 KiB) Viewed 4331 times
- LABEL+HELP.png (10.89 KiB) Viewed 4342 times
cool, thx
>jack the sound of underground<
