Mixbus 32C V6 - working with Scope XITE-1D
V6 just released - initial test shows it working with Scope XITE
Mixbus 32C working with Scope
My first test mix - love this mixer. Way better than V5
Mixbus 32C V6 New Mixer
SilverScoper
Re: Mixbus 32C V6 - working with Scope XITE-1D
Post by SilverScoper »
What known MB workaround components did you also install - Jack, asio4all etc ?
None. V6 over the top of V5. Project conversion worked - just had to do a once off slow plugin rescan. Also still experimenting how to do MIDI out to Scope proWave - bit of a challenge. But basic system and audio drivers work out of the box.
New review from AudioMasterClass
Good overview of new features.
mausmuso
Post by mausmuso »
Hey dante,
Did you have any issues with MixBus and SCOPE?
I cannot get the demo version (v6) to run.
It recognises scope ASIO and all the nidi inputs ok
Then is shows a small splash screen that indicates it is indexing plugin (or something like that),
Then it disappears and nothing happens there after.
Any advice would be appreciated.
I should add the is on Win 10 64Bit machine and XITE-1 Scope 7
regards
maus
I’m using Win10 x64 + Scope XITE v7.
I also got MIDI going and recorded out from Scope synth back into MixBus
Check my other post here
https://www.forums.scopeusers.com/viewt ... us#p343670
However these are just proof of concept. I haven’t used this workflow extensively as I’m still just stemming out of Reason into MixBus to get the best out of some older mixes.
I’m really waiting for either Reason VST rack plugin to work as a VST2 - or MixBus to support VST 3.
