I'm messing around with my XITE.
On one testproject the first devices took a few seconds to load.
Now there are some synths, mixers and effects in that project, but DSP is still below 50%.
When loading/inserting simple devices as masterverb oder SC-RMX160, the insertion takes minutes !
I can see the progressbar of loading advancing very very slow.
Sometimes I just kill the software after 10minutes, when nothing happens.
Unfortunately I cannot do anything to interact with scope in that situation. ( the music runs perfectly while loading)
Loading the complete project takes less then a minute.
If I insert the same device directly after project loading, it takes about 2min. Why so slow ?
What can I do to fix this ?
My setup:
A16 with Z-link on Xite, with PCIE card under Win7
very slow .dev loading on Xite
Re: very slow .dev loading on Xite
Hi if you can share the project, we can test it and try to reproduce your issue.
I just tried to reproduce the effect, but it currently doesn't show up.
The effect occured, when I was using wave_out with vlc and using a Webbrowser in parallel.
I also switched Xite on before the A16.
I know, this sounds mystical, but there is an unknown component to make my observation reproduceable.
Stay tuned
Stay tuned
