corrupted project in scope 7 / scope hang
nebelfuerst
Post by nebelfuerst »
I'm using scope7 with a XITE.
I used the legacy "bigmixer" with some drum synths. When connecting the out of Blackbox CWM to Bigmixer, I read "incompatible In32 Add 64 ..", then some dsp errors.
I saved the project, restarted scope and it worked.
Now I'm unable to add synths or mixer. The loading of them never finishes, scope needs the taskmanager to stop.
When deleting blackbox cwm, I can add new mixers and connect blackbox cwm without problems to them.
After doing some connections, I tried an insert and scope hang again.
Not really a nice behaviour, especially that I loose my work without warnings.
Is this behaviour known ? Some way to get around this ?
Re: corrupted project in scope 7 / scope hang
If Scope is in a bad state, it makes sense that it could sometimes have a problem saving. I do a lot of 3D work, and sound design work, and sometimes software crashes with both workflows. No matter the application, when it seems to be in a bad state, I always save *as a new version* (not over my current working project) before restarting the app (or computer).
