hi! anyone use BFD3 with scope on windows 10 64bit?
yowhi
Post by yowhi »
hello
i used pulsar 1 and scope 15dsp card with marian seraph ad2 audio interface(pcie)
all works perfectly on any daws on widows 10 pro 64bit.
but BFD3 was not. :(
bfd3 used in daw's plug in mode has not any problems just standalone mode is crashing and show blue screen with message
" fail : scScope.sys" then reboot..
so i need your helps
thank you
-------------------------------------------- intel core 2 quad cpu q9400 @ 2.66ghz
ram 16.0gm
windows 10 64bit
Re: hi! anyone use BFD3 with scope on windows 10 64bit?
It's trying to configure your Scope card for you, which Scope doesn't like. Try setting it to use the onboard sound, set your latency & samplerate settings (you may have to use ASIO4All to do this) to be identical to Scope, and then switch to the Scope ASIO drivers.
Alternatively, I use Plogue Bidule as my VST host.
