Hello good day. I have the following problem. I have 2 pulsar connected to an adapter converter to pci express and when I turn on Windows... me the problem of ...A commünication error with Pulsar2 (brd1) has occured. This problem can normally be corrected by relcading the DSPS. Do you want to try that?
I call the DSPS I save the project. I turn off the computer and give me the same problem again. Has someone happened or knows how to fix it?.
In the reboot it works well it is only when I turn off and on.
I want to say too. That in normal pci this problem does not happen to me. Thanks and greetings to all
DSPS problems starting windows
Re: DSPS problems starting windows
are you allowing the computer to sleep?
if the computer sleeps, it stops providing power to the card. when the computer wakes up, it does not recognize the card. you must fully shut the computer down and then boot from a powered off condition.
this is how it should work.
MIGUEL ANGEL
Hello, thanks for the answer. I think it was solved. It is not the subject you say. In 2 days I will tell you but I think I have solved it. I'm in tests and for now it works fine
