Solaris 4.1 + Qwave causes BSOD on Windows 10/Scope 7/64bit
petal
Post by petal »
I've been getting these for a long time, but couldn't find the time for the tedious trouble shooting process before now.
I'm unfortunately experiencing occasional (like in, some times it works) BSOD's on Windows 10/Scope 7 (64 bit) (Both XITE and PCI) when I load either Solaris v4.1 (Don't have v5.0) or Qwave (Qwave is the worst of the two though) caused by different sys-files:
Stop Code: SYSTEM_SERVICE_EXCEPTION
JBMidiEv64.sys
PAGE_FAULT_IN_NONPAGE_AREA
What failed: ScopeXite.sys
What failed: ScopePCI.sys
Both synths worked fine on my Windows 7 (64 bit) Scope 7 installation on this very same computer!?
I have tried to reinstall both synths with the newest files found from SonicCores website - did not do the trick.
I have trawled PlanetZ for a solution, found a few cases that seemed similar from when Scope 7 was first released, but the solutions found in these cases did not do the trick in in my case either.
Does anybody have any good ideas?
Also, I'd appreciate it, if others would please double check this and try to load Qwave a few times on a Windows 10/Scope7/64bit installation and see what happens.
Re: Solaris 4.1 + Qwave causes BSOD on Windows 10/Scope 7/64bit
Have you reported this on John's Zargmusic forums?
petal
Post by petal »
No - not yet. I wanted to check in with you guys first.
t_tangent
Post by t_tangent »
Have you checked those sys files are not blocked from running perhaps . Right click them from windows explorer and check properties. Just a thought? I don’t run Win 10 here so not sure otherwise
yes, did you download the 64bit sys files from the SC ftp?
petal
Post by petal »
OK - I checked the 64-bit sys-files and was told that "they came from another computer and might be blocked to protect this computer", I then checked the unblock-box on all 6 64-bit sys-files. Alas, I still get BSOD's.
I then downloaded both the QWave instalation and the 64-bit files from SC ftp and reinstalled them and checked the unblock-box on all 6 64bit sys-files again. Unfortunately I'm still getting BSOD's.
The MoBo I'm using is the one recommended by SonicCore: ASUS H81-PLUS.
Any other good ideas? :)
are you opening presets that use the wave oscs? those do not work in 64bit. delete any samples from the sample folder.
RP_001
Post by RP_001 »
I've had the same problem when I upgraded from Win7 to Win10. I had the same BSOD's, especially with Q-Wave. There were some "solutions" in the troubleshooting threads, but they didnt work for me. Not exactly sure what I did, and why, but I remember putting the 64-files (JBMidiEv64.sys, JBCtrlRp64.sys, JBCtrlSh64.sys, JBMidiNc64.sys, JBMidiPs64.sys) in de DSP folder instead of the SYS folder. When I then opened Qwave or Solaris, I still got the error "Can find JBCNTRLsH VXD" for each file, but those can be ignored, as the VXD is something for WinXP I've read here somewhere. Since this "trick" I can load Solaris and Qwave without BSOD's (only the vxd warnings that can be ignored)
Solaris + Qwave files.JPG (200.86 KiB) Viewed 7197 times
Please report your issues on John's forums here.
petal
Post by petal »
garyb wrote: Fri Nov 15, 2019 3:42 pm are you opening presets that use the wave oscs? those do not work in 64bit. delete any samples from the sample folder.
Nope - The device does not load to the point where I can change presets, it crashes the computer before that.
petal
Post by petal »
RP_001 wrote: Fri Nov 15, 2019 4:53 pm I've had the same problem when I upgraded from Win7 to Win10. I had the same BSOD's, especially with Q-Wave. I remember putting the 64-files (JBMidiEv64.sys, JBCtrlRp64.sys, JBCtrlSh64.sys, JBMidiNc64.sys, JBMidiPs64.sys) in de DSP folder instead of the SYS folder.
I tried this, it did not do the trick for me!
petal
Post by petal »
RP_001 wrote: Fri Nov 15, 2019 4:53 pm When I then opened Qwave or Solaris, I still got the error "Can find JBCNTRLsH VXD" for each file, but those can be ignored, as the VXD is something for WinXP I've read here somewhere.
If my memory serves me right, the VXD-files are a font-type for the plugins.
From the QWave manual:
"There are some custom files that need to be installed. These are in a folder called, ‘Quantum Wave App files’. Simply drag the Vxd and Sys folders inside into your Scope/App/ (SFP/App/) folder"
Do this, and you wont get the error-messages anymore :)
petal
Post by petal »
valis wrote: Fri Nov 15, 2019 5:26 pm Please report your issues on John's forums here.
Done:
http://forums.johnbowen.com/viewtopic.php?f=3&t=16816
Thank you
