Aux Dualizer for Mod mixers
Support & Discussion for Modular Mixer v2
Moderators: valis, spacef
spacef
Post by spacef »
For Modular Mixer v2 owner
The idea is to use a stereo aux send and be able to use 1 or 2 mono guitar pedals such as distortion. You can also use 2 mono pedal rigs in parallel.
In the Master Bus Aux Section, you can use this Dualizer as a pre (send) or post (return) Aux effect.
There are 4 routing that can be used as"Send" or"Return effect" with different purposes ( L / R / Dual / Thru)
To bypass the effect, select "thru" and switch off the blue leds of the inserts. This is used to record the dry return from the pedals.
-> Download it here
plug-ins for scope
SpaceF website
SC website
spacef
Re: Aux Dualizer for Mod mixers
Post by spacef »
Aux Dualizer is now "free for all" , no keys inside.
https://spacef-devices.com/news/aux-dualizer/
plug-ins for scope
SpaceF website
SC website
t_tangent
Post by t_tangent »
Thanks Mehdi,
Always appreciate your excellent devices :)
Spielraum
Post by Spielraum »
du nettes kleines ding du, hab dich :)
many thx
Perfect tool for external effects where phasing seems to creep in.
Sample Delay also helps but I was referring to PlateX outside of the mixer in the project window.
The phasing is a coloration that seems to come at 70-10% Wet Mix levels.
Placing this post Reverb pre AUX Return let’s me run Wet 100%, keeping the send levels lower.
Ankyu
