Xite-1 Heaphone Out
Xite-1 Heaphone Out
Inst level or line level? Guessing inst level.
Going into an external effects rack, sort of seems like i'm overdriving it.
Dual XLR out back to the Xite-1 analog inputs.
Welcoming words of wisdom, comments, suggestions :)
Re: Xite-1 Heaphone Out
line level.
line level can be +4 or -20. there is a volume level for the headphones out, so it should be possible to match levels if you use it for a send.
Its a great stereo send.
garyb wrote: Wed Nov 06, 2019 4:09 pm line level.
Dang it, forgot about that knob on the front. I'll try that and see. It's an old Digitech GSP2101 from the 90's that doesn't get fired up a whole lot anymore so it might not be functioning 100% anymore.
@dawman: would a TRS cable do stereo like that or is it another cable type?
TRS to XLR Splitter or TRS to Dual TS from Hosa work fine.
I even used the two mic pres on Solaris if I wasnt running @ 48k AES/EBU.
Juergen used a high quality AmpOp with an odd Ohmage on the headphone out too.
Hotter than normal.
My IEMs are a nice volume at 10 o’clock on the XBox.
Love the front panel on my XITE-1.
thanks
