SETUP: PULSAR II + DSP expansion - Scope v. 7.0 1706, CAKEWALK last version (previously SONAR), MOTU 828mkII.
Windows 10 64b upgraded.
I always used WAVE Dest/Source, now I wish to use ASIO.
Listing the ASIO Dest available I have only "ASIO Dest" (16b) "ASIO Float Dest" "ASIO2 Dest" "ASIO2 Float Dest",
it seems there are no 24 bit versions.
MOTU ASIO is 24 bit so I need to choose probably the same type for all.
Pls. help!
Bob
						ASIO 24 bit not listed
Re: ASIO 24 bit not listed
use the ASIO or ASIO2 source and the matching destination.
if your DAW is 24bit, the ASIO driver will also be 24bit.
You're right !  Setting DAW to 24 bits they appear as 24 bits.
But my DAW doesn't allow to use MOTU ASIO and SC ASIO at the same time... is it normal ?
yep, that is how ASIO works.
Correct.
Thank you for helping me.
I have found old projects of mine having "ASIO 24" and still working, that's why I was confused.
So, knowing that only 1 ASIO device can be used at once in the DAW, this is what I've done, succesfully:
- connected my SCOPE to MOTU 828mkII with two ADAT IN and OUT optical cables
- set my MOTU as "Master" clock
- set my SCOPE as "Slave" selecting ADAT as source sync
- in addition to the correct sync (without clicks & glitches), obviously, when I change clock in MOTU (44.1 48 96) it automatically changes in SCOPE
- in my DAW I choosed MOTU drivers and I see all INs/OUTs including ADAT ones (clock must be set accordingly to MOTU)
- I still can use SCOPE HW analogue OUTs connecting them to MOTU INs
good.
the MOTU is kinda "the department of the redundancy department", but whatever works for you...
