Hi.
I don't remember what to do but I remember there IS something to do !
I get the 'can't find DSP file DAS COEFF11 VxD' message. And the only DAS file that looks like that one is not a dsp file but a sys. Its name is : DAS COEF11.sys.
I must say that I turned cubase, VEP, jbridge and Scope in non admin mode. Too much plugins in which one can ONLY drag - drop files.
Anyway, who remembers the thing to do ?
Merci !
DAS COEFF11 VxD file missing
Re: DAS COEFF11 VxD file missing
get the 64bit files from the SC download server?
Well firstly, you havent said what plugs you're getting the issue on. What we do know from :
https://forums.scopeusers.com/viewtopic ... 11#p333234
is that the thing to do is use the special versions of DAS plugs that dont use it - eg DAS MASTERIT Lite and C350L
EG If you're reffering to MASTER IT - then have u tried MASTER IT EQ LT2.zip from http://www.digitalaudiosoft.com/ => Support => User Area ?
It works without COEF11
Shit ! You're right ! I forgot ! It's the legend eq.dante wrote: Sun May 26, 2019 1:04 pm Well firstly, you havent said what plugs you're getting the issue on.
The files that are in 64bits-Version --> win7-signed-SYS --> Highend-EQ-Bundle --> DAS LEGEND.zip are the same I've got in my Scope folder. Except the BypassMixS.dsp. The one I've got seems to be a month younger ! And it's 2.93 Ko, in the zip file, it's a 2.85 Ko file.
I can launch all other DAS eq. Just the Legend one doesn't agree to cooperate.
Ooops ! No the master it has the same issue. But not the LT versions.
I gonna try to fix that tomorrow... Need to sleep...
Thanks, Dante for help !
I think your outta luck - the DAS LEGEND doesn't have an LT version as far as I recall
DAS Legend working here on Xite-1 Win7 64bit.
(before you smoke your brain trying to figure this out do you have dNa Stereo EQ? it's a lot more elaborate)
It will work on Win7 because Win7 pre-dates the Microsoft Windows 8 KB update that broke it. That issue carries thru to Win10 as well unresolved.
Right, I think I remember that now. Other than the UI, I can't imagine why a security update would affect a Scope plug-in like this but fortunately there are other options. Sure would be nice to unhinge from the MS garbage.
I don't use Legend often, I just wanted to try it on a sound. I've got ple,nty eq, anyway, another one does the job.
But I like when everything works fine, even the stuff I use once a year.
If someone has a solution.... Otherwise, I'll try to go on anyway.
The DAS legend was good because of the Voltage Control warmer - but there's plenty of other plugs now that have something like that - both native and DSP. Console yourself that in using another EQ you will get the missing band back (7 Khz - 10 Khz) not covered by the Legend
