Anyone getting installation error from just having Xite-1D turned off for awhile?
jjgoss
Post by jjgoss »
I had my Xite-1D turned off for about a month, and when I turned it back on, I couldn't get Scope to load.
It kept giving me the following in a pop-up window:
Installation Error
Cannot start software because board(s) or driver not properly installed.
Please check the installation.
and this is followed by another pop-up window with:
Cannot start SCOPE
Cannot gain access to the SCOPE hardware!
This is after trying keeping the Xite-1D off, then restarting Windows 10, then turning the
Xite back on, then clicking on SCOPE XITE in my windows app list. I also tried restarting
the Windows machine, then turning the Xite on, then invoking SCOPE, but same thing.
I checked the cable from the Xite to the PC, the HDMI type that connects to the Xite
interface board in the PC. It is connected tightly at both ends.
Should I open up my PC and check to see if the interface board is in the PCIe slot fully?
Otherwise, I really don’t know what to do at this point.
Any help or advice is very welcome, of course.
James Goss
Re: Anyone getting installation error from just having Xite-1D turned off for awhile?
the XITE is not hot-swappable. it must be on and connected before starting the computer.
the computer cannot sleep when you use the XITE. it must be shutdown when done.
jjgoss
Post by jjgoss »
Thank you, garyb.
I followed your advice and restarted the whole process. In other words, I shut down my PC and Xite-1D, then
powered on my Xite, waited about 30 seconds, then powered on the PC (Windows 10). Once I could log in,
I went to the Windows applications menu and selected Scope Xite.
Once Scope was invoked, I got the same two pop-up windows (in succession) as before.
I am trying to find my notes from last year, but so far haven't had any luck.
Is there something more I could try?
Thanks!
James Goss
the XITE power light is on?
did you try another hdmi cable?
jjgoss
Post by jjgoss »
Hi garyb,
Yes, the Xite-1D green power light is on. No, I have not tried another HDMI cable yet. I will do that today or tomorrow.
I will also check inside the PC to make sure the PCIe card for the Xite is plugged in securely and correctly.
Thanks again!
James
jjgoss
Post by jjgoss »
Hi all,
Ok, thanks for the help, but "Never mind...", as Roseanne Roseannadanna would say.
Just a loose cable that I thought I had checked as being OK, but it obviously wasn't.
This is a great forum, BTW. And, garyb, I don't know how you do all that you do.
James
It's his superpower :)
:D
the important thing is that it's working...
jjgoss
Post by jjgoss »
"... it's working"
Three cheers to that !!
The more I use the Scope / Xite system, the more I appreciate just how cool it truly is.
And again, thanks to garyb, valis, and all you helpful forum members.
James
