Key for Scope 5.1
roberflash
Key for Scope 5.1
Post by roberflash »
Hi all,
I own a Scope 5.0 because I run in 32 bit system.
But need to migrate to 64 bits.
It's possible obtain a key for Scope 5.1 at no cost?
I want to try all my applications in 64 bits before buying Scope 7 system.
Thank you all
Regards
petal
Re: Key for Scope 5.1
Post by petal »
Upgrading from Scope 5.0 (which was free for people having v4.5) to Scope v5.1 was a paid upgrade.
Support the good cause ;)
roberflash
You are right, I paid two 4.5 licenses for two cards, in this moment.
But, I want to try before buy, there is somethings that no funtion at all in 64Bits.
Thank you
nobody here has control over that.
write to support for a temporary key to test v7. you can't really get a full demo of v5.1.
what doesn't work in 64bit?
mainly XTC mode, STS samplers, modular 4 tape delay, step sequencers...
roberflash
Thank you, Garyb.
I will write to support, asking for a temporary key.
asiofixer
Post by asiofixer »
scope 5 WIN 7 X64.png (156.61 KiB) Viewed 5956 times
hello i don't understand? because scope 5 work on winX64 !
no, it really doesn't, but do as you wish.
obviously, there are work-arounds and you have found them, which is fine for your needs.
enough.
asiofixer
Post by asiofixer »
garyb wrote: Sat May 18, 2019 6:10 am no, it really doesn't, but do as you wish.
enough.
sorry but ,first...
hello Gary !
I just want to tell you that it's easy to install creamware scope 5 on winx64 !
it work as 32 bit driver and ASIO DEUS LINK PRO is compatible !
all what i need ! as you say
that's why i don't understand why you say it really don't !
also don't understand your reject about asio multiclient, asio deus !
is planetZ a user creamware opensource forum ?
or a soniccore censure ?
cheers
I own these forums, not Sonic|core. Nice try though.
Not only do I support GaryB’s decisions, but note I have warned you already as well.
I realize there is a language barrier, but respect our users and share what info you know without beating us over the head please. This is your last warning.
you can think of this site as valis' living room.
don't get in a big fight inside the house and don't break things.
those are the rules.
if you wish to use O-Deus with v5 and it solves your routing issues, great!
not everybody has the same goals. for some, system latency is a pretty big thing, for others, not so much. O-Deus adds latency, that is a fact. if you only are interested in playback, then it does not matter. what DOES matter, is that every thread is not your personal space to crusade for your favorite preferences. you are welcome to provide your info once, which you have already done.
however, O-Deus is NOT available anyway, so there is nothing to discuss. there ARE cracked versions available, but we do NOT support or encourage cracks of ANY kind, not for ANY reason, EVER.
