New Labels
Scope project files
New Labels
New stuff from the ftp.
Re: New Labels
Post by JoPo »
Yeah ! They are great !
Re: New Labels
I only wish you could delete the colors name.
It’s just not essential being told yes this is red unless your vision is impaired.
Spielraum
Re: New Labels
Post by Spielraum »
dawman wrote: Wed Apr 24, 2019 7:49 pm delete the colors name.
mmhh... i think you mean "RNfo"
ok, realy easy fantastic workflow ~~~play with me
Line 1: Header (this line see always in Routing window and Sidebar after next scope start)
> is always immediately mirrored in the routing window
Line 2: additional text privat (only in Panel) or public (append in the routing window Header Text)
> privat: write text in panel, it will not show in window
> public: press Tx in left corner of line 2, text will appent to routing window header text
> public+privat: write additional public-info in line 2 > turn On>Off "Tx", now write private-info to see only in panel
Final > Your solution:
1. delete text in line 2 (text select + backward/forward delete Tab Backspace > Enter [Scope standard])
2. press "Tx"
3. now check text in routing window
Tipp:
move RNfo in your Sidbar to group devices "Set a headline"
for me is this a better workflow in big projects...
personal background info why developed our text helper:
1.) naming routing pipelines, pins, device captions, "direct visible" project infos, eye catcher
2.) readable headline in Sidebar
3.) flexi text elements in one device (see also "RNoteM", its realy flexible, can you find the button "Rx"? and "bind" buttons to combine Text of different presets?... for example only)
Not found Overview.pdf in the zip?
http://forums.scopeusers.com/viewtopic. ... 51#p339412
\o/
check, what differences you can see in Sidebar, Routing Window and Device Panel Surfaces, thats the Background Philosophy
Re: New Labels
Thanks, I got this from the ftp after seeing it on FakeBook and just started trying things.
I’ll see if I can tweak it to taste.
And thanks again for sharing.
faxinadu
Re: New Labels
Post by faxinadu »
neat stuff guys! very helpful for big projects
http://www.oceanswift.net
Music
