Styledriver Text Tools (SC Easteregg2019)
STDR / StyleDriver Official Developer Subforum
Moderators: valis, garyb, Spielraum, STDR
http://scope.zone/index.php?id=57&lg=en
... just sayin´ ...
Thx S|C !
Re: S|C Easteregg
Marco
Re: S|C Easteregg
Post by Marco »
Very nice! Frohe Ostern!
Mikael-R
Re: S|C Easteregg
Post by Mikael-R »
roberflash
Re: S|C Easteregg
Post by roberflash »
Thank you S|C
Re: S|C Easteregg
Post by JoPo »
That is genious !! At least one can have clear notes on the project window !
Is the "project presets" , 'PRJ preset list' module ? (Which freeze or crashes Scope, sometimes...) Or is there another one ?
Really a good surprise ! Doesn't support special characters with accents... Pity ! I hate spelling mistakes ! :D
Never happy... No it's awesome ! I gonna change my project template !
Spielraum
Re: S|C Easteregg
Post by Spielraum »
"...'PRJ preset list' module ? (Which freeze or crashes..."
what exactly do you mean?
> sur-audio project-preset device is fully supported,
testing for days in all directions was flawless.
> font typesetting is the simplest standard without extras, that's correct.
... for best performance and compatibility worldwide ;)
American Standard Code for Information Interchange (ASCII 7bit)
!"#$%&'()*+,-./0123456789:;<=>?
@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_
`abcdefghijklmnopqrstuvwxyz{|}~"spaces"
> note multiline: word wrap "Strg + Enter" (scope standard)
RNFOx also see pic:
https://forums.scopeusers.com/viewtopic ... f4#p339349
Re: S|C Easteregg
Post by JoPo »
Spielraum wrote: Mon Apr 22, 2019 11:20 pmRNFOx also see pic:
viewtopic.php?f=14&p=339349&sid=3e47bd8 ... f4#p339349
Great ! Isn't it more clear ?
Yep. Sometimes, after adding an fx insert somewhere, then recall a preset saved before, it crashes and even BSOD ! :cry:
I'm updating my template right now..! But the texte I enter in nfo modules, close to "Tx" doesn't want to appear nowhere !?
Re: S|C Easteregg
Post by JoPo »
Oh ! That's it I found how ! One must click on "Tx" to see the updated text !
Re: S|C Easteregg
Post by JoPo »
That's it ! Takes time ! A duplicate function like in modular would be welcomed, sometimes.
Project W.jpg (209.5 KiB) Viewed 23636 times
And it at last, it adds some color to the project window ! Most of audio applications are dark and grey, that's boring and sad. I like colors. :)
Spielraum
Styledriver Text Tools: S|C Easteregg
Post by Spielraum »
JoPo wrote: Sun Apr 21, 2019 8:00 am ...Is the "project presets" , 'PRJ preset list' module ? (Which freeze or crashes Scope, sometimes...) Or is there another one ?
JoPo wrote: Tue Apr 23, 2019 5:06 am after adding an fx insert somewhere, then recall a preset saved before, it crashes and even BSOD !...
... i think its normal, new synapses will not land
_____#####
___##_____##
__##_______##
_##__##_##__##
##___2019____##
##_____#_____##
##_____#_____##
##__#_____#__##
_##__#####__##
__##_______##
___###source:
*NEW LINK
https://sonic-core.de/product/styledriver-text-tools/
https://sonic-core.de/downloads/sonic_core/styledriver
#workflow:
##SR-RNxx-20190418a-Overview.pdf
t_tangent
Re: S|C Easteregg
Post by t_tangent »
Thanks for the Easter gift. Really useful. Vielen Dank :)
Spielraum
Re: S|C Easteregg
Post by Spielraum »
"...duplicate function like in modular would be welcomed..."
1. in modular all text modules always open,
2. raster grid need place for every module!
3. you can not turn off the grid
4. overflow not option in modular, or someone writes a pep for cable captions ~~
that´s the differnce to routing window
Re: S|C Easteregg
Post by JoPo »
Spielraum wrote: Tue Apr 23, 2019 1:55 pm "...duplicate function like in modular would be welcomed..."
that´s the differnce to routing window, and now we have
...actually a cheeky butt door
I mean the shortcut ctrl+Q after clicking on a module, then click on modular empty space duplicates this module. That would be convenient, sometimes in the project window too.
The S|C Easteregg are really great. Alas, for the non-note ones, when you want to write long text, you can't see the beginning or the end of the text ! What a pity ! Make the window resizable !
Spielraum
Re: S|C Easteregg
Post by Spielraum »
JoPo wrote: Wed Apr 24, 2019 10:30 am I mean the shortcut ctrl+Q after clicking on a module, then click on modular empty space duplicates this module. That would be convenient, sometimes in the project window too.
ahh, ok, dublicate DEV in routing window
yes, i miss this function often ~~
set it to scope X.X wishlist, because scope system conditionally
JoPo wrote: Wed Apr 24, 2019 10:30 am ...Alas, for the non-note ones, when you want to write long text, you can't see the beginning or the end of the text ! What a pity ! Make the window resizable !
in panel or in routing window?
i think you mean the panel surface,
yes, here will long text continue to run outwards!
here the background idea of "Rnfo", set a short Label to Lines/Devices with very small performance required.
> routing window will auto resize to text width
> line 2 offers more characters public with "Tx" append to labeltext, or let it "privat" only see in panel
> panel is fix and textfield is center formated, for best result in "Sidebar"-thumb info after next load scope ;)
if it were changeable, then one could recognize in the sidebar nothing more,
but i already thought that more text might be needed, therefore the textpanel overflow facility was integreated as exception,
write blindly or insert text from another source or editor.txt (actually meant only as an additional feature)
...also see "RNote" Note Multiline, extra for long endless text, with word wrap size to device-pin grid...
Re: S|C Easteregg
Post by JoPo »
Spielraum wrote: Wed Apr 24, 2019 11:12 pmin panel or in routing window?
Yes ! On the panel surface ! And you're right : fortunatelly, the all text appears on the project window !
Anyway, they're still very useful and thanks to their transparency, colors, direction and size, the best note modules !
dehuszar
Re: S|C Easteregg
Post by dehuszar »
Did they take it down from the home page? I'm not sure what folks were seeing there. New plugin?
Re: S|C Easteregg
Check the screenshots in this thread. I'll have to defer to GaryB for a current download link, the link has indeed expired.
Spielraum
Re: S|C Easteregg
Post by Spielraum »
the motto was: suche die vielen bunten Ostereier :wink:
▲scroll to link
