Scope 5 PCI compatibility
sethius
Post by sethius »
Hey guys can someone confirm with me which versions or windows Scope 5 PCI supports?
Specifically if windows 7 is supported?
k500zm
Re: Scope 5 PCI compatibility
Post by k500zm »
It works on Windows 7 fine and I am running it on Windows 10 it just needs a few tweaks but works ok
roberflash
Post by roberflash »
Hello,
but only in 32Bits windows, for 64bit systems it is necessary Scope 5.1 to run.
petal
Post by petal »
That is correct - The first 64bit Scope driver was v5.1.
asiofixer
Post by asiofixer »
scope 5 WIN 7 X64.png (156.61 KiB) Viewed 3784 times
scope 5 can work in X64 win 7 os i have done it!
Lotuz2019
Post by Lotuz2019 »
asiofixer wrote: Tue May 07, 2019 4:38 am scope 5 WIN 7 X64.pngscope 5 can work in X64 win 7 os i have done it!
Hi asiofixer,
Could you please tell us how you've done this or point us to the information? I'm considering an upgrade from Win 7 32 bit to Win 10 64 bit and to be able to continue using my CreamWare Luna I should upgrade from Scope 5.0 to 7.0 according to Sonic Core. As I only use it as audio interface and not for the effects and Instruments anymore, it's not worth EUR 165 to me. There are less expensive alternatives although they often don't have the same great routing capabilities as Scope. I'd rather keep using my Luna.
