Tape-Delay video
- the_mind_as_music
Tape-Delay video
Hi there all,
Was in the middle of exploring the tape-delay module when I saw the other thread, sort of rushed to get the video finished, but this is some of the things I was doing.
A lot of the modules in the Scope platform are my favourites, but the tape-delay is one of my special favourites!
If you fancy a listen,
the video is on YouTube here:
https://youtu.be/j_OC0Lqr2vQ
Instagram here:
https://www.instagram.com/p/Bv84_EzFtDj/
or Soundcloud here:
https://soundcloud.com/the-mind-as-musi ... odulations
Yours Delayingly,
Robert
Instagram here:
or Soundcloud here:
Yours Delayingly,
Robert
check  out my Sonic-Core Modular / eurorack emulations and other stuff here;
https://www.youtube.com/channel/UCauLvP ... kC_k6M_Fhg …?
https://www.instagram.com/the.mind.as.music/
twitter - https://twitter.com/mind_as_music
Re: Tape-Delay video
Robert;  That is very cool.
Have you had any problems with the Tape Delay Module?
Can you post your specs for reference (Computer, OS, PCI etc)
Thanks for posting stuff like that.
Dan
Dan
- the_mind_as_music
Thanks for your comments:
I ran up CPU-Z and here's some of the results:
Processor: AMD FX-8350 - socket AM3+ (942)
Mainboard: ASUSteK M5A78L LE
chipset: AMD 780G
southbridge: AMD SB700
LPCIO: ITE IT8728
BIOS: American Megatrends inc. 1601 - 12/07/2012 [!]
PCI-Express
Memory: DDR3 16gb - 2209.7Mhz
Running Windows 7 x64 and Scope 5.1
Also, 2 x 6 sharc dsp cards
All the things I've done and posted, I have never used more than about half on the DSP Monitor
And, as to the main point, never had any trouble with the Tape Delays.
Have had a few problems, but none related to the delays.
If you need any more info, just let me know.
Yours,
Robert
chipset: AMD 780G
LPCIO: ITE IT8728
PCI-Express
Yours,
Robert
Thanks Robert.  Just trying to get some info on why the Tape Delay works on some systems but not others.
Just a quick question, did you just install the Mod IV or did you update any of the Tape Delay files after the install?
Should I make a videos section in the parent site for this forum?
maybe, but what would be good is if Robert gave us a copy of his tape delay modules and the accompanying .sys files.
That I agree with.
						- the_mind_as_music
Hi All,
Here are my Tape Delay files that are installed on my system, I have a recollection that these were downloaded from Planetz.
In fact, I have found a bunch of files that might have been them, It includes some sort of driver.
I have included both here.
if there are any files that are 'missing' I'll see if I can find them,
Yours Sincerely,
Robert
Yours Sincerely,
Robert
				- jimmy V tapeDelay.rar
- Other files
- (377.55 KiB) Downloaded 562 times
				- TapeDelay files.7z
- My Tape Delay files
- (244.78 KiB) Downloaded 542 times
Is your system 64 bits ? It estonishing you don't have any issue. I'd like to know !
Which .sys files are in your Scope sys folder the Jimmy's ones (in which the sys files seem different : older and not the same weight !) or the ones in 'tapedelay.7z' ?
Thanks for the info !
- the_mind_as_music
Yes, its Windows 7 x64, also, the files in the .zip 'TapeDelay files' are the ones in my system.
Just checked to see if the midi controller function works and that seems to be OK.
I've done another Tape-Delay video above,
Have a listen!
Robert
Have a listen!
Robert
- the_mind_as_music
(or watch)
- next to nothing
Thanks, that's how i remember it. Updated driver and new .sys files.
Well, really weird ! They are the same files I've on my crashing computer as soon as I use them !
- next to nothing
i didn't try them yet, but did you update the driver?
But the driver is for Scope 5.1 ! Should I use that one ??
						- next to nothing
If you are on v7 i would not recommend it, no.   at least for now....
 at least for now....A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort.
Yes... So the best now is to ... wait !   It is the SC way of life. That's ok ... I'll survive.
 It is the SC way of life. That's ok ... I'll survive.- next to nothing
Well, based on the current progression, give it another year or 10 and it might be fixed
unless you do it....
