Old user from the past here.. (wow it's been 17 years :S )
Two Pulsar2 cards in a DAW machine from 2010, running Scope 7 in Windows 7 x64.
My Pulsar cards work fine and I can use the lowest ULLI with no problem but occasionally I have clicks and pops even when listening to an mp3 in media player. The machine is DAW optimized and runs RME Babyface at a buffer of 64 without any issues.
While trying to understand what might be the problem, I paid attention that whenever I had an audio dropout the Sync Source lights in the Samplerate Settings Window blinked as if I connected something to the SPDIF or the ADAT (I have nothing connected).
Sometimes lights insist blinking and the cards are unusable. But if I disconnect the cables-thing (sorry, can't remember now how it is called :S) and reconnect it the issue gets fixed.
What might be wrong? Somewhere I had read that this might be caused by a faulty STDM cable. Could it be? I want to try fixing it with all easy things first, before considering something more drastical. If the STDM cable may be the cause, then where do I find a new one?
Thanks!
 .. Is WD-40 good for this job or I need De-oxit? I have LOGO 100 as well, which is an anti-rust spray made in USA but sold under this name in Greece.
