50Hz buzz
nebelfuerst
50Hz buzz
Post by nebelfuerst »
Some time ago, I had the ( stupid ?) idea to use cables which convert asymetrical outputs to symetrical.
This way I attached my old synths to an A16 ultra.
Unfortunately, 50Hz buzz was present more intense than before.
Today I switched back to "mono-cables" and the buzz is gone.
Is there a reason, why I should try to use symetrical inputs for my old synths ?
Re: 50Hz buzz
They are not balanced outputs most likely. There are various ways to break the inverted side of the connection documented online, or you can use a DI box (this can also add some nice color), or you can use this: https://www.musiciansfriend.com/amplifi ... eliminator
Re: 50Hz buzz
no.
whatever way works best is best. it's all about eliminating ground loops.
Re: 50Hz buzz
This is what the Hum Eliminator is doing internally
Re: 50Hz buzz
Here's a good article that covers this in more depth than I can muster right now. I'll attach the relevant image here and reference that it's probably #14 that interests you, but I do suggest reading the article too if you have time.
Re: 50Hz buzz
don't usually need a transformer in the first pic...
Re: 50Hz buzz
anyway, when connecting balanced devices to unbalanced devices, there are often significant level differences as balanced lines are usually +4 and unbalanced lines are usually -10 or -20. there can be impedance mismatches as well. surprisingly, there is no such thing as a standard, although there are conventions...
Re: 50Hz buzz
Agreed on those points as well
nebelfuerst
Re: 50Hz buzz
I used setup 14, but the cable was 1-conductor shielded. ( so black and green in pic 14 was identical)
When using 15, all is quiet again.
I also tried a DI-Box, but it didn't help. Probably due to my cabling ?
As gary said, I'm happy to find at least one solution, that works.
But being a curious person, I'd can't stop experimenting :-)
Re: 50Hz buzz
here is the "bible" for audio engineers. if you REALLY want to be pedantic, you can buy the latest edition on Amazon or similar...
https://soundsfxedit.files.wordpress.co ... ndbook.pdf
this is all the basic information an audio engineer needs. remember, the guy that runs the train is the engineer. if you own a studio, you are supposed to be one. otherwise, you're just a monkey with his hand on the throttle of the train... :lol:
