Which power supply to use with an ASB unit (polarity)?
Discuss the Creamware ASB and Klangbox hardware boxes
paugui
Post by paugui »
So...
I was going to play a bit with my Creamware Pro 12, but forgot to bring the power supply I have always used with it and on the back it mentions only 12VAC...
Can anyone tell me what polarity should I put on the power supply?
Would really love to play with it a bit as it has been a while since I used it...
Thanks in advance,
Best
Paulo
Re: Which power supply to use with an ASB unit (polarity)?
AC doesn't have polarity. only DC has polarity.
What country are you in Paulo?
Mr Arkadin
Post by Mr Arkadin »
Yeah, be careful not to use a DC supply if it says AC.
paugui
Post by paugui »
Sorry for such a late reply...
According to the manual, it works well with AC or DC power supplies:
If you lose the power supply, a standard AC or DC 12V / 1.5A power adaptor can be used as a replacement. The PRO-12 ASB's power socket requires a hollow plug (5.5 mm x 2.1mm x 11.5 mm, centre positive).
I have used one with centre positive (as they mentioned a bit after the V and A requirements) and it works great and still sounds amazing! :D
Mr Arkadin
paugui wrote: Fri Aug 31, 2018 9:17 am According to the manual, it works well with AC or DC power supplies:
That is a really cool feature as I remember the early Line 6 POD guitar amp sim had an AC supply and loads of people killed them with DC replacements. To be able to use both is genius. I love my Taurus 3 pedals because they work at 110v/60Hz and 230/50Hz straight from the IEC.
