32 bits to 64 bits
Ditykman
32 bits to 64 bits
Post by Ditykman »
Hello everybody.
I am a happy xite user. I've got my config under windows 10 32 bits ok.
But I have ableton live 10 and it's only 64 bits.
So what is the way to go to 64 with my scope folder? can i paste it or do i install everything?
There are a lot of plug ins (zarg, DNA, COS2...)
regards
DragonSF
Re: 32 bits to 64 bits
Post by DragonSF »
Answer: there is no way. as for 64-Bit the VST (XTC) plugins don't work at the moment.
what?
most people don't need XTC mode.
you can paste the scope folder. i would put the Scope folder in C:\programs and then run the installer into that folder.
you will still need to put overwrite some sys files(that Scope asks for when you load the plugin) with the 64bit version.
your presets and devices should all be in place that way.
DragonSF
Post by DragonSF »
garyb wrote: Thu Jun 28, 2018 5:21 pm what?
Sorry, my misunderstanding. I thought, the OP wanted to run Xite plugins with Live 10.
Ditykman
Post by Ditykman »
Hello
Thanks for the anwsers.
The install inside the old foder make sense!
thanks a lot for everything
Mix and plug ins in scope = the best way!
regards
