PCI cards and X-1D Install advice
- ChristianB
HI
Decided to sell my portable and jump on an open box offer for a ASUS Prime H270-pro.
Now I'M looking for some help to install properly my SCOPE family and see what would be the best.
2x PCI pulsar2 cards on Scope 5.1
1x XITE 1D on Scope 5.1 and 7
Is the Scope 5.1 compatible with windows 10 (64) ?
if yes
Should I install the PCI with Scope 5.1 first or should I go for the Xite version 7 first ?
Once both installed should I disable the ASIO driver of the PCI pulsar-Scope 5.1 in order to avoid conflict with the Xite driver ?
The way I see the hole thing is : I'm gonna use the PCI as if it was on an external computer... midi in/out - Audio out (ADAT) to the Xite.
Is there a better way ?
Thanks a lot
if yes
Thanks a lot
Re: PCI cards and X-1D Install advice
I can just answer to this question, that Scope 5.1 is compatible with windows 10 64bit and works with no problems.
I'm using it on 2 computers , both windows 10 64bit.
cheers
that should work. both ASIO drivers can live together. you will have to choose in any given app, so don't disable a driver. it doesn't matter which gets installed first.
- ChristianB
Great! Thanks
Will try that tomorrow!
That's pretty much the only way. Details here : http://www.hitfoundry.com/issue_12/pcx_mast.htm This example is based on Cubase and ADAT - I use Reason and SP/DIF now but the same principal applies.ChristianB wrote: Mon Apr 09, 2018 6:50 am The way I see the hole thing is : I'm gonna use the PCI as if it was on an external computer... midi in/out - Audio out (ADAT) to the Xite.
Thanks a lot
Well, if XTC-mode gets up and running with scope v7.? then you could run your XTC-cards in XTC-mode enjoying all the benefits of having the SCOPE synths inside your DAW. Then you hook up the PCI-system through ADAT into your XITE and enjoy all the benefits from running Scope in Scope-modeChristianB wrote: Mon Apr 09, 2018 6:50 am
Even though your daw is using the Asio-driver from the PCI-system, you will still be able to access the Midi-drivers from your XITE-system.
I have done the above with Scope v5.1, but never could get it to run 100% stable.
- ChristianB
Trying to install first pulsar card that has 5.1... result in none installation of the driver.... then tried to update manually the driver with same sad result.
Please note that I have now the same exact MoBo as Sonic core office with exception of the RAM memory. Asus Prime H270-pro.
See attachment
See attachment
- update driver 5.1 - 2018-04-10.pdf
- (211.25 KiB) Downloaded 272 times
ofcourse, did you try this first ?ChristianB wrote: Tue Apr 10, 2018 6:26 am Trying to install first pulsar card that has 5.1... result in none installation of the driver.... then tried to update manually the driver with same sad result.
To enable driver signing :
run CMD (command prompt) like administrator , copy / paste :
bcdedit -set loadoptions DISABLE_INTEGRITY_CHECKS
bcdedit -set TESTSIGNING ON
restart
install drivers, software .....
and then after you installed all drivers for cards ...
To turn it off again, use these commands:
run CMD like administrator and then again copy / paste
bcdedit -set loadoptions ENABLE_INTEGRITY_CHECKS
bcdedit -set TESTSIGNING OFF
restart
- ChristianB
fidox, I just tried your command prompt suggestion, Here the result :
C:\Users\User>bcdedit -set loadoptions DISABLE_INTEGRITY_CHECKS
The boot configuration data store could not be opened.
Access is denied.
C:\Users\User>bcdedit -set TESTSIGNING ON
Access is denied.
C:\Users\User>restart
'restart' is not recognized as an internal or external command,
operable program or batch file.
Access is denied.
Access is denied.
as to the method of disabling driver security, either the bios has Safeboot enabled, or you did not use an elevated command prompt.
here are two methods:
https://www.howtogeek.com/167723/how-to ... d-drivers/
ok, here we go again :
first -
go to All Programs - Windows System - (right click) on Command Prompt and run as administrator
then copy - paste :
restart Windows 10
when you get back into windows, install software and drivers ....
restart windows 10 again,
then go again into :
copy - paste :
restart windows 10,
hope that helps more now
first -
then copy - paste :
restart Windows 10
copy - paste :
restart windows 10,
- ChristianB
By right clic on cmd and choosing I got the first line to work!
C:\Windows\system32>bcdedit -set loadoptions DISABLE_INTEGRITY_CHECKS
The operation completed successfully.
C:\Windows\system32>bcdedit -set TESTSIGNING ON
An error has occurred setting the element data.
The value is protected by Secure Boot policy and cannot be modified or deleted.
try what garyb suggested and check also :
those lines which i wrote should work, i have done that tons of times
- ChristianB
I had to go via the BIOS to disable unsigned driver
- ChristianB
Now I got both Scope PCI and XITE-1D opening.
Next chapter DAWS and pluuuuuuuuuuuuuugins.
Thanks for your help
