5x scope cascaded...
Spielraum
Post by Spielraum »
fake or true??
see media review from 24.02.2010
https://www.thomann.de/de/cat_amazona~n ... =2755&ar=2
"... Dadurch dass sich bis zu fünf Karten verbinden lassen,
konnte man die Anzahl der Ein- und Ausgänge auf jeweils über 120 erhöhen. ..."
"... Because you can connect up to five cards,
you could increase the number of inputs and outputs to over 120 each. ..."
mmh... not only 3 cards cascadable
has someone tested this?
Re: 5x scope cascaded...
not fake, just not really possible on most motherboards. there were some early experiments back in the very early Creamware days using custom motherboards that revolved around 5 card systems, but 3 is the maximum practical limit.
Spielraum
Post by Spielraum »
...thats amazing,
cool! the hardware does not suffer.
My conclusion, I'll try it on 5pci board step by step
the power supply is enough
do you have the old CW computer specifications/ boards still in the drawer?
for orientation...
you will waste your time. you are not the first. :)
Spielraum
Post by Spielraum »
you're right!
I also talked to Frank
"... static PCI ..." overflow etc.
because of thought MADI on 4th card
Ok, fantasies deleted
