Midi cc modulators/lfo
General discussion for SpaceF Devices
Moderators: valis, spacef
Liquid EDGE
Post by Liquid EDGE »
What (of your devices including free and black box2)
That send midi lfo cc signals and retrigger(the lfo) on midi note input?
Re: Midi cc modulators/lfo
Post by JoPo »
Hi, liquid !
I believe there is no Spacef LFO outputing directly midi. But I may be wrong !
But you can do that easily with modular, you just need BCmodular collection.
midi lfo.jpg (123.01 KiB) Viewed 36573 times
Midi lfo.rar
(487.19 KiB) Downloaded 856 times
Liquid EDGE
Thanks Jopo.
That’s amazing!!!
Post by JoPo »
You're welcome ! I think I'm becoming a modulation specialist between different applications. Modulating through midi is nice but through audio between DAW & Scope signal is much better ! But if you want to send modulation signals to hardware synth, I'm afraid there is only midi. I've seen on your studio that you've got an Usamo box, it could drive your midi modulation signal with nice timing !
W_ellis OSC Scope modules seem to be very promising too. But I didn't try it yet.
Liquid EDGE
Yeah very good point on usamo. As it’s usually when I start throwing midi cc modulation movement out, when jitter and timing issues stuff can start to happen.
I’m intending to modulate (with re triggering) my doepfer dark energy synths!
Will download that file/zip tonight. Your a star! 😊
There's a few other options too
http://www.planetz.com/Pulsar/files/devices/foam.jpg
and if you want a more professional bundle of midi tools including a syncable LFO midi generator:
https://www.sonic-core.net/shop/product ... 23e9da1ed7
Liquid EDGE
Foam seems cool, I’ll have a hunt/search.
Yeah I did want to get that os midi commander pack! But already spent enough over Christmas. Tbh. It seems a bit pricey for midi tools at full price.
spacef
Post by spacef »
Hi all,
There is no SpaceF device that does this directly (as far as I remember, but I could be wrong :-) )
In BlackBox II there was a CC morpher that could take any audio/midi signal and output it as 5 modified midi CC.
I currently have a project to do this in, a better way, but I haven't had the time to start yet. So alternative solutions are welcome :-)
plug-ins for scope
SpaceF website
SC website
next to nothing
Post by next to nothing »
I might be misunderstanding, but any LFO etc in modular can easily output midi to your sequencer, if you have a value monitor with an assignable slider. i use Flexor for this, see http://forums.scopeusers.com/viewtopic. ... ur#p251832
Liquid EDGE
spacef wrote: Tue Jan 30, 2018 12:09 am Hi all,
So I could use the modulators that came with mod mix v2 send those signals to the morpher and basically have midi cc modulation. Cool will check it out.
Liquid EDGE
next to nothing wrote: Tue Jan 30, 2018 11:54 am I might be misunderstanding, but any LFO etc in modular can easily output midi to your sequencer, if you have a value monitor with an assignable slider. i use Flexor for this, see http://forums.scopeusers.com/viewtopic. ... ur#p251832
Ah very cool. Yeah that’s basically the sort of thing I’m looking for but with re trigger lfo on note input.
How very cool modular is. Recently got hold of flexor 3 as well!! 😊
Post by JoPo »
I missed the Flexor trick ! It looks very fun with the elastic module ! :wink:
If you send midi notes to the little patch I showed you, the lfo wil be retriggered on each via its gate input and the retrigger button on.
Before the sync tot async module, the signal is sync format, allowing you to mix it with other sync signals with a mixer. Those other sync signals could come from envelope, lfo, modular audio input, flexor's lfos etc. And even async signals which allow you to use logical / math modules from BC & CW modular, just convert them into sync to mix them with sync. Or any other sync signal source. So, you can shape your modulation signal, before to convert it in midi cc, the way you wish.
I noticed that if you want an accurate signals, you should use sync modules as much as possible.
Spielraum
Post by Spielraum »
one of the many reasons why scope is so awesome for me
Yes Scope is awesome.
Scope 7 and OS MIDI Commander are on my short list.
at0m made a great LFO to MIIDI Patch I added retriggering to.
I use it to retrigger TC Fireworx Phaser Sweeps and SpaceF Mixer Channel Filters & Pans.
