XITE driver issue
Ricardo
XITE driver issue
Post by Ricardo »
I have a new ssd drive and have been trying to do a new install of Win 7 and Scope 7 on it. I still have the scope 5.1 on another HD ( dual os at present) However when I try to start SCope 7 on the ssd it is telling me the device is not installed correctly. In the device manager, it then has a yellow exclamation mark next to the xite hw, where previously it was fine. I have re installed the drivers several times, and the scope 7 install detects the xite, but always the same result on start up of scope.
Have I forgotten something in the process, may be a tweak somewhere, or is there a conflict? Or do I need a new brain....(been very busy since Xmas, and was looking forward to this, so may have missed something in my enthusiasm)
I haven’t even got as far as inserting any key files yet!
Any help would be very much appreciated
R
Re: XITE driver issue
the XITE was powered and connected before the computer was started? sometimes simple things...
right click the device manager entry choose "update driver". choose the driver from the list. if the v7 driver isn't in the list, then there is an application to install the driver in Scope\driver\win10.
sure! try another slot.
Ricardo
Post by Ricardo »
Hi Gary
Yeah tried the usual pitfalls. The driver was on the list. It does install but then uninstalls when Scope 7 is started. I’ll try a New driver from the site and try a New slot, although no issues previously with that.
See how I go
R
Ricardo
Post by Ricardo »
now resolved. turned out that the PCI driver hadn't installed correctly.
R
Ricardo
Post by Ricardo »
Was masterverb pro upgraded at all? Sounds much more clearly defined. May be the fresh install on a new ssd and fresh OS.
No more problems and all up and running. Awesome
R
i think everything sounds better in the new version...
Ricardo
Post by Ricardo »
I think you’re right... I’m havin’ a ball .
R
