Anyone here with experience on Dante Network with scope?
I have a pc with scope environment running as the heart of the studio. I try to connect a macbook with ableton  16channels via Dante to scope7. On the Pc site installed 'Dante Via' and on the mac site 'Dante Virtual soundcard'.
I get two channel audio transfer comming in via the scope ''Wave Source 1', so now go for 16 channel transfer.
There is no way I can get it running on ASIO which it should.
What am I doing wrong here?
Thanx in advance.
						Dante Network configuration for Scope7
Re: Dante Network configuration for Scope7
well, you can use 8 wave modules...
the Dante app won't work with Scope ASIO? you could use Reaper w/ReaRoute or VoiceMeeter as a bridge, since they will accept the Scope ASIO driver and provide a virtual ASIO driver for your other apps, allowing you to route Scope and any other apps together, even multiple apps.
https://www.vb-audio.com/Voicemeeter/index.htm
https://www.reaper.fm/
Thanx Garyb, as soon as I have a spare minute I will check Voicemeeter out. The website looks promising.
SOLVED ...!!
So, took the time to do a complete system wipe. formaly windows7 with a lot of unwanted stuff going on.
Installed: win10 Pro , Scope7, Dante Via.
No problems anymore recognising the ASIO driver. Works like a charm.
