I had a problem installing Scope 7 (PCI) in windows 7 x64. Having been solved , I would like to let know other possible users how to solve it.
I had problems installing the windows 7 update kb 3033929.
According to Scope 7 installation instructions, this windows update has to be installed previously to the Scope 7 installation. (and of course it is necessary, otherwise, Scope installs but doesn´t work)
Apparently, there are a lot of windows user having troubles to install this update.
In my case, I had an infinite loop, the kb 3033929 installations started but never ended.
After reading A LOT of forums and trying a lot of different solutions, eventually, something very simple worked fine to me.
It was doing a clean boot in windows 7.
See here: https://support.microsoft.com/en-us/hel ... in-windows
After doing the clean boot the kb 3033929 update installed without a problem. After rebooting the system the Scope 7 was installed ok.
An issue occurred, anyway. After installing this kb update I needed to re-install the ilok drivers (So I suppose that the infinite loop problem was caused by the ilok driver)
Please, be aware of this. This is a very simple solution.
After some days playing with Scope 7...it rocks¡¡¡
Long life to Scope¡¡¡
