[resolved]windows 8.1 start - scope error
babaorum
Post by babaorum »
At the starting of win 8.1 I have put scope in the start-menu, there is always this issue :
https://www.dropbox.com/s/nnv0c5sosgztv ... r.jpg?dl=0
Sonic Core Luna II + Pulsar II scope v5.1.2709-x64, Cubase 9.0.20 (64), Pro Tools 12.7, Wavelab element 9 (64), windows 8.1 pro (64), Asus P6T 18Go RAM core i7 920, SSL Duende Native - Lexicon PCM Reverb Bundle - Waves - Sonnox
Re: windows 8.1 start - scope error
Scope is not intended to autostart as it needs to run "as administrator".
fidox
Post by fidox »
I have always simple project at startup with windows (minimized).
babaorum
Post by babaorum »
I have remember that I putted scope in normal mode for the start and only if I have needed VDT Ihad to start in admin mode.
fidox
Post by fidox »
Try like on picture,
I have tried now on my other computer, also running scope, but i didn't have under startup before.
Also make sure that under "Compatibility" "run this program as an administrator" is unchecked (disabled), just leave run as administrator under advanced option.
I have Windows 10 Home and Pro, works on both now with those settings, you said you have 8.1, but i think it's the same.
babaorum
Post by babaorum »
I have unchecked but I have still the issue ... ?
fidox
Post by fidox »
did you try creating string key , like on picture in registry ?
well, every computer is litle different, so it's hard to say.
babaorum
Post by babaorum »
ok now it works scope is starting at each session of windows but with the error message.
I didn't try the key in register I'll try immediately to know if it's that ;)
babaorum
Post by babaorum »
Even with register's key , there is an error message. But scope starts ...
missing WWindows.dll ...
fidox
Post by fidox »
when i was trying at first, i also get this missing file, but it has something to do with administrator rights...cause i was just playing around "run as administrator" + registry key, that's all.
just like on pictures.
fidox
Post by fidox »
other thing came up my mind ,
if you have under security for C: full permissions for administrators.
babaorum
Post by babaorum »
Where are you looking for this param ?
It's really annoying, with v5.1 all were right for the boot , now it's worse ... with v7 ... :-?
Scope is not supposed to autostart.
babaorum
Post by babaorum »
but it worked with v5.1 ...
Ok I remove from windows start ...
babaorum
Post by babaorum »
RESOLVED ! it works but it's the quicklink which has to be in the start menu not only the .exe because there is '-s' in the command line !!!
ha ha
fidox
Post by fidox »
babaorum wrote: Mon Dec 18, 2017 11:10 pm it works but it's the quicklink which has to be in the start menu not only the .exe because there is '-s' in the command line !!!
great!
yes, indeed. you can see that on my pictures, that it was shortcut of scope, sorry if i didn't mentioned that. :)
babaorum
Post by babaorum »
Yes , shortcut ;)
pwhitmaker
Post by pwhitmaker »
garyb wrote: Tue Dec 05, 2017 7:34 pm Scope is not intended to autostart as it needs to run "as administrator".
Why does it needs to run as administrator?
fidox picture up here helped me to get autostart working in Scope7.
But the Icon is no longer visible in the lower right corner of Windows 10. Its there, but invisible.
sunmachine
Post by sunmachine »
pwhitmaker wrote: Thu Dec 21, 2017 8:24 am But the Icon is no longer visible in the lower right corner of Windows 10. Its there, but invisible.
See here for a fix, please: viewtopic.php?p=332779#p332779
fidox
Post by fidox »
pwhitmaker wrote: Thu Dec 21, 2017 8:24 am the Icon is no longer visible in the lower right corner of Windows 10. Its there, but invisible.
interesting.
never had such an issue, probably cause i'm using classic shell application (sadly, they have stop development)
