Scope 7 Bug List
djmicron
Scope 7 Bug List
Post by djmicron »
Hi, the idea of this topic is to keep track of the old/new bugs of the new scope 7 software and hope everybody will write it down here in the form of:
Operating system version
Scope Hardware
Ulli settings
Sample Rate
Plug-in (if the bug is plug-in related)
Type of bug/error message
Other relevant information
If a bug has been already submitted, don't submit again and eventually quote the bug message with additional information(another operating system, another sample rate etc.) so that it will be easy for Sonic Core to read.
Thank you
djmicron
Re: Scope 7 Bug List
Post by djmicron »
OS: Windows 10 64 bits
Hardware Xite-1
Ulli 6ms
sample rate 48 Khz
Plug-in: SB 404
error messages:
A capacity limit of your dsp cards has been reached.
The specific cause is:
Cannot add module Amplifier 12 dB
it is often possible to solve this problem by means......
as Faxi said, that's not enough, step to recreate it:
load the plug-in.
faxinadu
Post by faxinadu »
Thats not goid enough. Must include exact steps to recreate ☺
http://www.oceanswift.net
Music
djmicron
Post by djmicron »
Hardware Xite-1
Ulli 6ms
sample rate 48 Khz
Plug-in: Every Plug-in using sequencer modules(Solaris, modular modules, WC Pro one)
type of bug: Sequencer settings unresponsive until dsp reload(reallocation or sample rate switch)
djmicron
Post by djmicron »
faxinadu wrote:Thats not goid enough. Must inclyde exact steps to recreate ☺
just loaded it.
faxinadu
Post by faxinadu »
djmicron wrote:OS: Windows 10 64 bits
Hardware Xite-1
Ulli 6ms
sample rate 48 Khz
on scope 7 are you sure? it should be fixed.
Music
djmicron
Post by djmicron »
Hardware Xite-1
Ulli 6ms
sample rate 48 Khz
i hoped so, but it looks like they tried to fix it on the sb 404, all the rest is not working at all
Post by JoPo »
- The project window, on 'hide desktop' mode, doesn't follower screensets anymore ! Argh !
- The mouse scroll wheel doesn't roll up & down the project window, on 'hide desktop' mode as long as I don't have touched the project window vertical scroll bar.
I guess those annoying behavior aren't related with ULLI, plugins, SR, etc...
sunmachine
Post by sunmachine »
I noticed two minor graphic issues.
1. The Meterbridge and Notepad modules are still black:
2. The new Note field in Lightwave doesn't disappear when you switch to another page (and it's missing the inner shadow):
Post by JoPo »
Midi CC modulation range knob still useless ! A pity ! Some kind of working feature like that in Scope midi implementation would be awesome ! :(
Ditykman
Post by Ditykman »
Hello all
The midi cc recall with nthe STM mixers (24 and 48) still not working just opening the projects
The feature would be very usefull
Than,ks
Scope 7 Plug In : SC-BrickWall EQ Crash :
OS : Win 8.0 x64
HW : Scope XITE-1D
CPU: i7 4790 (not overclocked)
MB: Asus Z87
RAM: 16GB
ULLI : 12ms
Sample Rate : 96KHz
Reproduce: Drag and Drop SC-Brickwall from device menu (Effects/Stereo/EQ/SC-Brickwall EQ) to project window.
R6025 Crash
R6025 Crash
it's ok, here. perhaps something from the v5.1 files if you merged them?
i don't have an XITE to check here atm.
maybe if you repaired the Visual C++ library... you could rerun the installer.
Nebukadneser
Post by Nebukadneser »
Could someone post a "sticky" on how to make a proper new install of v7 over previous versions? What to do: remove the 5.1 by cutting it from the file browser, or make a new install over the existing 5.1. And, what is the best way to re-install third party plugins?
Neb
look, i'm gonna just say it.
RIGHT NOW, the old mess from v6 is finally cleaned up and things can get fixed.
write a NICE letter to SC and explain the problem, how to see it, and the chances are better than great that you will get satisfaction. a nice letter explaining the problem will be much more effective than me trying to explain it.
getting hackles up, pointing blaming fingers, acting like you're being ignored will not help.
this thread will not help.
since it's a known bug(by the users), there is a strong desire to eliminate it on Holger's part. what do you want? he's done all this by himself, since the hired help just took money and left a mess. it can't be fixed by waving Harry Potter's wand.
garyb wrote:it's ok, here. perhaps something from the v5.1 files if you merged them? i don't have an XITE to check here atm.
If it works elsewhere I suspect its my OS, which has been infected and cleaned by SpyHunter & hardly any OS patches installed. Next workstation & new OS I suspect it will work.
Yes, Holger's done an awesome solo job. I view this update as a line in the sand and a stepping stone to future workstations.
sunmachine
I can load the Brickwall EQ here on my XITE-1 without problems. I even tried it with 96 Khz.
I'm on Windows 7, 64-bit and did a clean install of SCOPE 7.
I tried at 44khz and it still happened. Its definitely my workstation.
Shot
Post by Shot »
OS: Win 7 64bit
Scope Hardware: Pulsar2+Luna
Type of bug/error message:
Had few problems with autostart in windows.
Initially it wouldn't autostart Scope app (even though it is in msconfig/startup)
I had to manually place the shortcut into Startup folder under "All Programs"
If it had no "-s" it would then start, but if the link contained "-s" then it wouldn't start
Tried with and without running it as administrator
Fix was to go to cset.ini and replace DontRestart=1 to DontRestart=0
Now it is starting minimised as it should
Shot
Post by Shot »
OS: Win 7 64bit
There is no icon when Scope is in windows tray!
It is present there, you can click the empty space and get the Show/ExitScope menu, but the icon is blank!
It's nothing critical but it's fun to have SC icon there, isn't it :)
